Before:
After:
I did all the prep work myself - Pulled the roof rack/ribs & flares, patched all the holes with Devcon Plastic Steel putty, then sanded the whole truck with 220 & 400 grit to get the old oxidized clearcoat and base coat down to something paintable. I then masked it and sprayed 3M "rocker panel spray" over the lower part of the sides to cover up my flare hole patch jobs, similar to what a lot of guys have done with Line-X or Rhino.
When I took it to the paint shop, I just had them mask the windows, lights, etc and spray it with DuPont single stage urethane "464 Beige". I didn't want to spend a LOT of money on it, so when you open the doors, hood, tailgate, etc, you still see the old paint underneath. I can always touch that up by hand later if I decide it bothers me.
Cost breakdown was roughly as follows:
$100+/- Sandpaper, sanding block, masking tape, etc
$ 95+/- three cans of 3M Rocker Panel Spray
$ 25+/- for the 40+ hours of sweat I put into the prep work
$350 Paint and body shop
When I first called the body shop, he guesstimated $1500-$2000 if he did ALL the work and did it 100%.
My under $600 job is close enough for me!
I do still have some buffing to do to make the final finish "new car smooth", but I have to let the paint cure for 3-4 weeks first. Also, I probably should have been a little more liberal with the rocker panel spray - 4 cans would have been about right. I can still see my flare-hole patch jobs pretty easily if I'm looking for them. She looks a WHOLE lot better than she did though!
After:
