Instructions to adjust throw out hearing
You can use the search function. I know I posted pics of the fsm instructions many times. Set pedal height, adjust pedal freeplay, then the rod at the slave. All adjustments per the fsm specs.
The throw out bearing is not adjustable, it slides on the front bearing retainer of the trans. The pushrod in the booster is adjustable, the pedal has adjustment and the slave push rod is adjustable.
