I can say this for sure: if I make the tooling to rebuild the original vac unit, they will run $125-175 for the vac rebuild by the time I make the necessary internal parts to complete the rebuild, and make the tooling to be able to reassemble them properly. The aftermarket single vac units are inexpensive and can be modified to work properly. In my 13 professional years rebuilding distributors, as well as the 17 years prior doing it just for fun, I've never seen an application that needed a dual vac like this one. Its a 2-stage vacuum advance, which is just silly. under higher or lower vacuum, the unit should be able to apply the correct amount of advance at the correct vacuum level. Period. This setup makes no sense. Its overly complicated and even when it works as intended I don't believe its working as well as a good single vac unit could.
