Looks like a nicely made exhaust
I ended up finding a deal on a Torqit exhaust and installed it this weekend. Shipping from Australia was fast and easy, straight from Torqit.
I would have liked an exhaust that routed through the frame but those were all 4xx stainless. This exhaust is 304 and a work of art, really great construction.
Removing the old exhaust was fine, just tedious getting to some of the more obscure bolts. Ratcheting wrenches and flex joints made it much easier. Soaked everything in liquid wrench for an hour or so and everything came right off.
I couldn't figure out how to remove the rear section that routes over the frame/axle so I just chopped it in half.
Stock was pretty squashed in some areas
Very happy with it so far. I went with the louder option, straight through with just a small resonator. It sounds awesome but I will be careful when driving around my neighborhood at night, it's loud. haha. I'll make a video soon
No way?? I'd like to see the standard version if that's trueThat's the factory installed, high performance exhaust option
They are all squashed in that section
Yes, you're right, they only have one option routed like stock. I looked at a bunch of different options - the only exhausts that routed through the frame were Manta, Redback and one other I can't remember now. They looked great but they were all 400 series stainless, which I don't think would hold up well to US winter weather.Looks great! I looked it up, and it looks like it runs around $1200 U.S. Dollars. I didn't see one on their site that's routed through the frame. Was that one available somewhere else? Also wondering why you didn't choose that one. Look forward to see (or rather hearing) the video.
I wanted to go with 304 stainless for the winters here, so that limited me to PPD, Beaudesert and Torqit. PPD seems to be made in China, but Beaudesert and Torqit are both made in Australia and really well made from what I can tell.
Haha yeah I figured. Agreed on running it inside the frame, wish I could have found a 304 system that did that. Down the road I'll look into a custom setup but yeah for now it's a great updrade.It was a facetious comment
I've built a couple of exhausts for my diesel cruisers, it surprised me to discover how flattened the stock exhaust is at the rear cross member.
That system looks really sharp.
I personally prefer to run it inside the frame, you can eliminate all the sharp bends and really straighten out the exhaust pathway a lot.
I think what you have is still gonna give a good upgrade.
So i've got basically no knowledge of running exhaust on the diesel models. (or gas for that matter) What is involved in running one inside the frame?
I can't lie there was a little part of me hoping for a hood stack.... *snail noises* tsu tsu tsu tsu tsu psshhhhh *coal trail*
Do it!!That respray full desert dune looks amazing! I suggest go for it. Tempting me to do mine too....
Looking good. For the rear bumper recovery, can you find a piece of metal to be made into a spacer? Thickness would be for how low the recovery points you would want for them to hang down. That to me seems to be the easiest solution looking at the pictures. Also, you wouldnt happen to have a contact email with the person you worked with at Torqit would you? I emailed them and the person replied with…”we don’t have any exhaust systems compatible with your vehicle.” Thank you.Small upgrade today. I bought Roadsafe recovery points from The 4WD Shed in AU. They were easy to work with and the shipping was fast.
The fronts bolted right up after a thread clean up with a M12x1.25 tap.
Before:
After:
For the rear, I don't have any immediate plans to buy a bumper, and as far as I can tell you shouldn't use the 4 holes on the rear bumper for a recovery point. Right?
I've seen a few guys running these recovery points on the rear: (photos taken from Australian FB groups)
They claim they mounted right up so I bought an extra set. However, the stock bumper gets in the way -
The first hurdle as you can see is that the welded bumper mount makes it so I can't mount these flush with the frame rail. I could hammer that down a little and use a 1/4" spacer - it wouldn't need to be too big. Thoughts?
(That flat piece of metal directly behind the left hole.)
The second hurdle is that the holes are threaded on the LHS, but on the RHS, the holes are not threaded. I could potentially use some of these nuts on a stick provided with the Roadsafe kit, if I can get them in the frame.
Let me know if you guys have any ideas. Easiest thing would probably be to sell this second set and just pick up a more standard type like a Trail Tailor recovery point.
I'll PM youLooking good. For the rear bumper recovery, can you find a piece of metal to be made into a spacer? Thickness would be for how low the recovery points you would want for them to hang down. That to me seems to be the easiest solution looking at the pictures. Also, you wouldnt happen to have a contact email with the person you worked with at Torqit would you? I emailed them and the person replied with…”we don’t have any exhaust systems compatible with your vehicle.” Thank you.
Before:
After:
Before:
After:
Dude I have the exact same issue with rear recovery points.
I tried to use the Trail Tailor recovery set but had the same problem with the welded portion getting in the way and one of the holes not being threaded. I'm looking into rear bumper replacements but the OEM swingout is an issue for most of them.
