If the hf2av uses 3 gears to drive the output shaft in high range, how does the underdrive kit work? (4 Viewers)
Sounds like you need LS vs LX or Avalon vs LC.
Since I am in the planning stages of a 6.2L Gen5 swap into my LX450 I am anxiously waiting on results of the new idler gear. I want to do the 9% overdrive to help out with the final drive ratio since I will have plenty of power available. I plan to keep Displacement on Demand and look to get good fuel mileage. Planning for limited off road, mostly on road use, quiet tires etc.
Anyone else use the OD gears on a V8 swap?
Hardly, when I say Limited Offroad, I don't live in Colorado and or Moab but when I go there I do off road the trails/mountain passes, hard to do with an LS/Alvalon.... Long drives pulling a trailer to get there from Oklahoma as well.
yeah, thats a terrible idea. search on here and you will find several members that had major issues with it.
Not with the Gen5 engines and direct injection. Yeah the older versions were troublesome. It can be removed fairly easily if necessary. I daily drive a 2015 Silverado for work with a 5.3 gen 5 and I love it.
Yeah, but what about tire size? :rofl:
We have that too ;)
Next question? :D
I’d like to buy the 900731 so I can have 1:1 high and 3.1:1 low.
Can you send me a price?
Pricing is all current on our website:
As well as here on Mud:
80/100 High Range 10% Overdrive Gear Set - 8x/100 Series Land Cruisers
Fits 1/1990-1/1998 8x Series/LX450 and 98-07 100 Series Land Cruisers/LX470. Fits factory full-time (HF2A/HF2AV) transfer cases found in US Spec and global market Land Cruisers. These gears offer a 10% overdrive in high range, equivalent to converting axle gears from the 4.10 to 3.70 gears without having to do ring & pinion work. 100/470 Applications require additional input shaft parts, call for details.
Part# TCG9007ODHR - $505.00
80/100 High Range 10% Underdrive Gear Set - 8x/100 Series Land Cruisers
Fits 1/1990-1/1998 8x Series/LX450 and 98-07 100 Series Land Cruisers/LX470. Fits factory full-time (HF2A/HF2AV) transfer cases found in US Spec and global market Land Cruisers. These gears offer a 10% underdrive in high range, equivalent to converting axle gears from the 4.10 to 4.56 gears without having to do ring & pinion work. 100/470 Applications require additional input shaft parts, call for details.
Part# TCG9007UDHR - $505.00
80/100 3.1:1 Low Range Reduction Gear Set - 8x/100 Series Land Cruisers
Fits 1/1990-1/1998 8x Series/LX450 and 98-07 100 Series Land Cruisers/LX470. Fits both factory part-time (H1FA) and full-time (HF2A/HF2AV) transfer cases found in US Spec and global market Land Cruisers. Includes both low speed output gear and idler gear. Minor case clearancing is required using a die-grinder, otherwise these are a direct fit to your 80/100 Series transfer case. Factory ratio is 2.49:1, these 3.1:1 gears offer a 25% low range reduction with no change to the 1:1 high range. Made in Japan to OE Toyota specifications. 100/470 Applications require additional input shaft parts, call for details.
Part# TCG900731 - $725.00
Import 80/100 3.1:1 Low Range Reduction Gear Set - 8x/100 Series Land Cruisers - Trail Quality
Fits 1/1990-1/1998 8x Series/LX450 and 98-07 100 Series Land Cruisers/LX470. Fits both factory part-time (H1FA) and full-time (HF2A/HF2AV) transfer cases found in US Spec and global market Land Cruisers. Includes both low speed output gear and idler gear. Minor case clearancing is required using a die-grinder, otherwise these are a direct fit to your 80/100 Series transfer case. Factory ratio is 2.49:1, these 3.1:1 gears offer a 25% low range reduction with no change to the 1:1 high range. Trail Gear
Part#
TCG303846 - $409.50
Give us a ring if you would like to order. 801-563-1277 We can ship as soon as today!
Part#
TCG303846 - $409.50
I checked but did not see the 3.3:1 pricing option.
There you go. Bryce will be calling back. :cool:
Just talked to Chris. He said someone would have to call me back on the 3.3:1 pricing.
I just tried calling you back and got a voicemail that isn't setup. I'll try again in a few minutes.
To achieve the 3.3:1 low range, you must do the high range underdrive and one of our low-range t-case gear options as shown in the gearing chart. As both the high range and low range are driven from the input gear (see the chart for the gear teeth count) you change your low range with a high range change as well. Hence how the 3.1:1 gears get 3.3:1 in the end. Clear as mud?
Part# TCG9007UDHR
- $505.00
AND
Part#
TCG900731 - $725.00
OR
Part#
TCG303846 - $409.50
Price with all Japanese would be $1230
Price with Japanese high range gears and import low range would be $914.50
Call us when you're ready and we can fine tune the pricing when buying either combo. Both are in stock and can ship as soon as today! 801-563-1277
Part# TCG9007UDHR
- $505.00
AND
Part#
TCG900731 - $725.00
OR
Part#
TCG303846 - $409.50
Definitely will call within the next two weeks. I think the 1.1:1 high (which when compared to 410s is equivalent of 456:1 ring and pinions - which is nice with 35” tires) and 3.3 low range is a very marketable combination. Saves the hassle of regearing front and rear ends plus gives a lower overall low range than one would achieve with ring and pinions alone. I’ll be in touch soon!
Precisely :cool:
I'll make you off our call-back sheet for the moment, buzz us when you're ready and we'll make it happen!
What is the additional step / work required for the hundred series?
The 100 requires a new input shaft and clip. We can provided the needed parts.
I'll get some pictures posted but Dave did some fantastic side by side gear mesh/pattern photos with the stock gears and the stock idler, stock gears and modified and our high range gears and the modified idler. In the end we both agreed the pattern with the stock ideler was better than the modified idler when using UD gears. Next up to try the modified idler with OD high range gears.
So, it's our opinion moving forward they the UD gears will be installed as they have for the last decade and as we've experience with all lower gear sets 4x-8x, some additional noise should be expected. Jury is out on the OD high range gears until we can mimic Dave's install meshing.
