GTSSportCoupe
2LTE abuser
- Thread starter
- #381
Appreciate the insight, i'll have to pickup another compression tester and hope for the best.
This has urged me to look more in depth into the cooling system, i thought i could get away with it for a couple more months due to the lower winter temperatures, but im quickly nothing can stop the 2lte's doing what they do best. Might just start a build thread at this point, more so for my own sake of documenting what i do, and for others to give me input, instead of spamming this thread with every problem i have.
EDIT: From what i glean, if either the head or gasket are already gone, nothing else can really hurt me short of a tow home, and I don't plan on any road trips in the near future. So i think my current plan is to overhaul the cooling system, and keep a close eye on everything, and get some proper working gauges asap.
Have a happy new year!
If the cylinder head that was put on it was a genuine Toyota one and the job was done by a reputable shop, I'd be inclined to think your cylinder head is fine. If the job was done poorly and rushed, there is definitely a chance of head gasket issues, although a 'blow-out' is unlikely, as these are multi-layer steel.
My 2LTE's head gasket was leaking when I first bought my truck. But it never got worse. Just let gasses by when running under high load. I had assumed it was a cracked head, so bought a new head and all the bits, only to find out it was just shoddy workmanship by whomever had replaced the cylinder head. It's been 100,000kms of abuse on my new head since, and I've had no issues. I abuse mine harder than anyone else I know.
So I think your decision to service your cooling system and see how things go is a good decision. Don't spend money on a new cylinder head until you know for sure (visual) that it is the actual problem.
A fresh rad cap is a no brainer. Bad rad caps can cause all sorts of problems. I think these rad caps cross over to the late model 60 series... (HJ60 say), and other Toyota models.
A fresh OEM t-stat is another no brainer. Rocky Mountain Imports carries the 82C Toyota OEM one. They're awesome. They start opening at 82C by the way. Fully open at 90C or so I think?
After loosing coolant, its normal for bubbles to come out into the resevoir for a few days as the air works its way out. However after a bunch of cycling (a week of daily driving say), there should be no more bubbles. If there really is a problem with the head, bubbles will come out worst when motor is (or has recently been) under high load for a long period. So a good test is find a long steep highway grade and push up as hard as you can. Stop at the top to pop the hood (leave engine running!). Very carefully (so as not to burn yourself) inspect the overflow tank. Pull the lid just enough that hose stays in the coolant. Use a flash light to peek in and look for bubbles. If you have an idle-up control in the LN130, keep the engine running around 2000rpm while you do this. If you see bubbles, you may indeed have a cylinder head or gasket issue of some type.
Only other thing, is look for coolant leaks. Where coolant leaks out, air can be drawn back in as the system cools. This can be a cause of never ending coolant loss, and bubbles coming out in the reservoir. Replace any suspect clamps in the system. Even the little hose that runs from rad cap to over flow. Air can get drawn into that even. A bad rad cap will let air in too.
Good luck!
