Thanks. Can you describe a bit of the type of improvements you’re seeing with them?@woody where are they at ride hieght. It's really rare to have both wheels at full droop.
@Box Rocket, Adam they are one of the best things I've done to my suspension. While not on the slinky set up you two are I'm on Slee/ADS shocks and Slee springs.
Gotcha. Thanks. Curious to hear woody's feedback. I don't overrun the stage4 slinky shocks very often (if at all, even when the truck has been airborne) so I'm debating how noticeable these would even be on my truck.Basically at any high speed full compression there is not that hard hit into the bumpstop. They provide a very progressive stop at the end of the suspension travel. Honestly not near the issue now with my Slee suspension. But was night and day with my old Ironman as the spring rate was way lower and I blew through it constantly.
You aren't trying hard enoughGotcha. Thanks. Curious to hear woody's feedback. I don't overrun the stage4 slinky shocks very often (if at all, even when the truck has been airborne) so I'm debating how noticeable these would even be on my truck.
Haha could be. I'll see if I can get more air next time.You aren't trying hard enoughI've overrun mine and had some hard hits.
@Corbet full droop with both may be rare, but it takes once for that bump/mount to contact the tire and cause an issue. I HAVE completely unloaded my suspension while wheeling.
I'd be curious to see any interference on the CTI setup that MetalCloak has....maybe at EJS I'll get a chance.
I get that. But your still running the OEM link locations right?
So I guess what I'm saying is that your going to have some lateral movement of the axle through the travel. If the only place you have contact is at double full drop (both wheels) then that is probably the best scenario as it's the least likely to occur.
If you can eliminate it there too without compromising something else then obviously even better.
Seems like the factory bump inside the coil could be modified without too much trouble to accept these? Would solve fitment issues no?Adjustable links, but OEM locations...yes. I'll get it on the CTI in a few weeks at EJS and get some pics. (Or call Corey and have him bring it by the house...lol)
Good point Adam, as the Timbrens are held on to their mounting plate/base with a single bolt so this solution could easily be adapted to the factory bump stop location inside the rear springs. Maybe even for the front springs too?
Maybe just need to develop some bucket reinforcement for anyone that can't play nice with their toys.That plus the appropriate spacer just might work. "guessing" the Timbren should be positioned at full bump so full compression meets the top inch of the bellows.
HOWEVER...you are then relying on the coil buckets to absorb the full hit....IMO, not a great idea (my fronts are tweaked already). The frame is a far stronger point for that mount to contact.
Haha could be. I'll see if I can get more air next time.![]()
yeah I know. It's weird the trucks just end up flying sometimesView attachment 1638803 View attachment 1638804
I don't know what your talking about......it happens all the time
Agreed! Stock front bumpstops on mine with 1" taller frame mounted bumps in the rear.View attachment 1638813
note:
still stock bump stops here
the amount that some of these "solutions" limit up travel is a bit excesive
