How to install A/C in a 1st Gen Pickup/4Runner (8 Viewers)
I ran across another forum. Is this how I'm supposed to set it up with a T since it only has one larger port on the diaphragm
Plumb it for the type of valve that you have. If it's not the original type that had the extra port for the power steering, yes you hook it up like the post you found.
What I was saying in my last post was to basically run the vacuum directly to the throttle body and see if it idles up. Bypassing the valve as a test.
Im gonna try as per picture and see what happens.
Ok update for those who plan on taking this project on. If you use diaphragm below then you will need to T off the throttle body port to the diaphragm and power steering. I had been scratching my head for a year trying to figure out why it wouldn't idle up sure enough this fixed it. I used 1/4 brass T
Part No.: 88606-32010
DIAPHRAGM SUB-ASSY​
1​
mail
Part No.: 88690-22470
VALVE ASSY​
Trying to repiece my 87 Turbo A/C back together. It was missing the 2 hoses and compressor. I'm on the lookout for a compressor bracket currently and wondering what differences on 22r compressor mounts there are if anyone can post up. Thanks!
bracket needs to match the pump. there are at least three different brackets.
I get it since you have a compressor. I just see a TON of these posts on various forums. I put a lot of Sanden compressors on various old vehicles that didn't have A/C over the years. Easy to find, not too expensive and easy to fab brackets for. I just wondered if it wasn't a good fit for the old Toyota 4 cylinders for some reason.
Denso 4710131
Ok my extra one is not going to work for you. However if you look at my build in this post, top picture, you can see the bracket I think you need. Builds - BluezClues Build '79 RN37 Pickup - https://forum.ih8mud.com/threads/bluezclues-build-79-rn37-pickup.1246417/post-14947433
this is from a 85 4runner and the bolt pattern seems to be the same as the A/C compressor from 96 land cruiser which means they used the same 4 through bolt pattern for a number of models, years and compressors. If you want me to confirm the pattern, get some measurements from the 4 through bolts on your compressor and I will compare on my end.
