How to install A/C in a 1st Gen Pickup/4Runner
Yes, pulled from the low and high side r12 ports
Edit: So played around again with it for about 30 minutes. Swapped to a different fitting, seems to be holding pressure at the fitting. Looks like my leak is coming from the 2 manifold ports attached to the compressor so gives me a bit more confidence what to do next.
Add boost to your AC when temperatures get to 100°. Settings on recirculate by level Max AC. It's colder than it's ever been.
AC is now blowing ice cold as of last night. Will be curious on my way home from work today how it does in 95F+ temps.
Ended up being the 4 o-rings on the bottom of the manifold ports on top of the compressor. OD was slightly smaller than the original R12 O-rings, not allowing it to make a complete seal when installed.
