How much gas left when fuel light came ON? (1 Viewer)
Test vehicle: 2003 LX470
I was able to get about 2.5 gallon of gas out through the fuel pump since the low fuel light came on.
With the fuel tank empty, I had to add 5 gallon of gas to have the fuel light off.
YMMV.
Stock truck, 5spd, cruising a Kansas interstate at 70mph could see 15 mpg.
No way with a 25mph headwind that will always be blowing at you you no matter which way you are going.
I measured 16-17 with 4sp truck driving long distances. I get stable 13 with mixed city driving (not stop/go, just regular suburbs)
Same with mine.
My gas light blinks first @ ~20-gals, then seems stay on @ ~21-gal.
FWIW...I logged 18-mpg over 860 miles to Milwaukee this past weekend. One tank recorded 19-mpg. I drive pretty conservatively, rarely going over the speed limit.
Normal city mpg's range from 10-13.
[QUOTE="94SRUNNER, post: 13207277, member:
[/QUOTE]
Thats key right there. If I go 65, I can get pretty good mileage, but it exponentially decreases after that. In NV with 80mph speed limits (so everyone goes 90+) on certain highways, I get 11-12 at 95mph. Thats with 34s and stock 5spd gearing. I imagine that would be worse with a regear.
What is everyone's cruising range when the light comes on? I know the computer is probably a bit conservative, but mine always seems to be around 20 miles until empty. Seems tight.
Mine was ~15 miles
Yes sir
33" tires and a awning are my only modifications..
I can get 15-16, but im driving 65 and cruising, accelerate calmly vs. aggressively... drive it like a tank, if I want to gun it i drive something else more suited for that.
Stock truck and tires, Denso TT plugs, can get 16-18.5mpg on premium fuel depending on conditions. I’d guess that would mean 45-60 miles once the fuel light comes on...
For you guys getting 15 mph +, good for you all. I've got a lightly built (bumper, winch, sliders, awning, roof rack), supercharged 98 and I'm getting about 12 mpg, no matter how I drive it. Don't really mind the fuel efficiency (or lack thereof) when I smash the pedal and hear the supercharger - can't put a price on smiles per gallon!
Mine was 5 gallons at reserve. However, it’s more like 3 gallons for the past couple years. I’m guessing there is increased resistance in one of the connections. I haven’t dug into it yet. Gauge displays normally, otherwise.
Reserve seems to be about 5-6 gallons in my 98. That’s in line with my FJ62 as well.
Probably a resistance or sender issue but figured this might be a good place to ask.
my gauge will be on Full or slightly above after fill up and within 20 miles drop to a quarter. The next quarter will go fast too but the second half of the tank holds out for a long time. It takes all the fuel it should and ultimately I get decent miles out of a tank but it bugs the crap out me. I haven’t seen anyone else mention this issue here or I’m using the wrong search terms
It is interesting this does pose a concern for more people, but the fuel tank does not hold a consistent volume from full to empty. I don't think the fuel gauge has variable resistance, so it would make sense the "top 1/2" is used faster than the "bottom 1/2".
It is interesting this does pose a concern for more people, but the fuel tank does hold a consistent volume from full to empty. I don't think the fuel gauge has variable resistance, so it would make sense the "top 1/2" is used faster than the "bottom 1/2".
yea, most cars I’ve driven for long enough to notice do go through the first half faster. It is just way more pronounced than I’ve seen before.
