Drill out the spot welds, remove and replace with a replacement wheel well.
GL
ED
Now that's creative........![]()
You asked how to do it properly.
OK. What else? What would the DIY be for that rotted flange up against the new quarterpanel?
a little bondo never hurt.
thats a joke haha
I hate my PO for doing that to this day! Can't wait to put steel back into my cruiser.
That has got to be the biggest laugh yet! YOU OWN A CRUISER! Where did you plan on saving money! See you on wrench day! Unless I get some time off from work.
You could weld in an L or T section it seems instead of replacing the whole thing and still cut out all the bad metal
also you could do it in a couple sections to keep the body together as you work
You would still miss those rolled sections so it should come out looking normal
that way you are only fixing whats bad and keeping whats good intact --all new seems a bigger job and greater expense and it should look the same either way when finished
work small welds and join them to keep down warping
Pin_Head - I should have gotten your advice before cutting into the back of minePut a rubber mat or carpet over it and wait 10 years until it gets worse.
