- Thread starter
- #61
Not sure if that little electric fan is up to the task of handling 110 degree potential ambient temperatures with the relatively low CFM rating, hahaha. I even considered swapping it out for a large or higher CFM fan for the benefit of the AC in low speed situations.
Considering the size of the condenser and the fact that its before the radiator I don't think its undersized, though its more likely that its an auxiliary component thats meant to only supply enough airflow at low speeds and the main fan would take up most of the load. In your case if your radiator temps are high in traffic then your condenser performance will likewise suffer. What I mean is that I think the kicker fan is adequately sized for any AC load at low speeds provided the radiator temps are inline...if they aren't its probably not.
I think once you figure out whats giving you high low speed coolant temps your AC performance will improve dramatically without needing to do any fan clutch or electric fan work.
