Help.I have a 1995 80 series diesel landcruiser and antifreeze is leaking out of the heater inside
Oamaru nz
Can someone suggest where to start to repair the leak.At first glance it appears as though I will have to pull the whole heater assembly apart .Is there a procedure or more simple answer.
I don't know the diesels. On petrol models you can bypass the heater lines where they come in the firewall.
You can bypass the heaters on the diesels as well. That gives you time to pull out as much of the dash as needed to get the heater unit out / apart for repair or replacement.
