Headlight wire harness FJ60 and FJ62--And now for FJ40
I have started building these headlight harnesses again. I've updated the harnesses since these prototype pictures. The harnesses I build now look a lot better.
After 20 years or so, the headlight wiring in our Landcruisers is just not up to the task. If your headlights are dim and yellow, you know just what I am talking about. Well, it’s time you did something to remedy this unsafe condition.
ULTIMATE HARNESS. Each headlight harness is built around the BUSSMANN weather tight enclosure and comes ready to install. You will simply disconnect your headlights, install the harness, route the wires to the headlights and connect everything up. All wiring is heavy gauge automotive wire. All connections are crimped with a ratchet crimper and insulated with sealed heat shrink. All headlight connectors are high temp ceramic. FJ60 & FJ40 harnesses can be used with stock sealed beam headlights or H4 high power headlights. FJ62 harnesses will come wired for H4/H1 headlights. If you wish to use the harness for stock sealed beam headlights, you will need to purchase a set of adapters for $15. The ULTIMATE HARNESS comes with an additional feature: You can also control auxiliary circuits. The FJ60 & FJ40 harnesses can control 2 Aux Circuits, and the FJ62 harness can control 1 Aux circuit. (NOTE: See post 13 in this thread for more info on the Aux relays.)
AUX RELAY BLOCK. In addition to the headlight harnesses, I also build an Auxiliary Relay Panel. This option is for those that have already upgraded their headlight wiring, but desire a compact solution to control additional high power accessories such as fog lights, additional driving lights, compressor, etc. This is also based on the Bussmann fuse/relay panel and will control five Auxiliary circuits.
See the link below for more info on the AUX PANEL:
LINK>>>Aux Relay Panel<<<LINK
Some customer feedback:
"….the harness works great. I am really happy with the package. Kind of reminds me of Apple products, they just work and are user oriented…"
"I wanted to write a quick note on how nice these harnesses are, I just installed one for one of my customers and it was easy and worked great."
"I'm waiting on Daniel Stern to send some lights, but I can already tell a difference in the stock lights. The harness is top notch."
"….this thing is a work of art…"
"…works as advertised…"
A NOTE about installation: FJ40 harnesses are built to install the relays/relay module by the battery on the flat surface just behind the coil. FJ60 harnesses by default are built to install on the PASSENGER side wheel well or inner fender wall, FJ62 harnesses are built to install on or above the DRIVER side wheel well. (all US spec). If you will need to have the harness built for an alternate installation location, please let me know when you place your order.
Wondering which headlights to buy?
Please see my "Headlight Bakeoff" thread for more information on headlights:
LINK>>>Headlight Bakeoff Thread<<<LINK
Special instructions here for Hella ECE headlights for your FJ62:
LINK>>> Hella ECE Headlights for FJ62<<<LINK
As an aside, my headlight harness is plug and play. It plugs into one of the vehicle headlight sockets that you disconnect when you install my harness. This provides the control to the harness. So, your headlight ON switch, and your HI/LO switch must function correctly. If you are currently having problems with your stock headlights, you must fix this before you can use my headlight harness. Please refer to this thread for help fixing your stock headlights:
LINK>>>Headlight Troubleshooting Thread<<<LINK
You should also refer back to the headlight troubleshooting thread (above link) after you have installed new headlights for instructions how to aim your new lights.
And finally PICS:
View attachment 416147View attachment 492098
