A couple months ago I was at a friend's house, and when I tried to start my car to go home, there was a horrible grinding that turned out to be the starter. After towing it home and replacing that, it started wonderfully, except a nice plume of white smoke out of the tailpipe. A few tests later and it was obvious that the head gasket was toast, so I started gathering materials for it.
Fast forward to 2 days ago when I completed the whole job (including valve job/tipping and taking off .005" of the machined surface) and I was feeling pretty good about myself. The only problems were a code 26 off the check engine light and a lower oil pressure than I saw before the rebuild. It was about half way between the bottom line and the next line at idle, and at the second line at driving speeds. I also decided to run the timing 6 degrees BTDC instead of the factor 3 degree setting.
Now today I was driving up a hill with the pedal all the way down just to test it out, and it got to about 50 mph and wouldn't go any faster. Then at the top of the hill I could start hearing some kind of knocking sound so I let off of the throttle and the engine completely died. Luckily I could coast all the way down to the next red light where I successfully restarted it and drove the last 4 minutes home gingerly.
As soon as I got home I put it back to the factory 3 degree BTDC setting on the timing, but by then it was knocking regardless. I got worried about the oil pressure so I replaced the sender with a mechanical gauge, but I sat it on my bumper and when I started the engine, it fell off and broke! So real readings will be coming as soon I as get another.
It seems to knock a little at idle, then a little more when accelerating the engine, and not as much at a steady high rpm or when decelerating. I took a video and the sound seems pretty accurate. I have put so much work (and money!) into this car in the last month or so and I just want it to work!
Could it be detonation? Pre-ignition? A spun bearing? Rod knock? Maybe the oil pump decided to go? Are all of these issues related somehow? Are there any more tests I can do to help diagnose? Thanks in advance!
Here's a video:
Here's a video:
