- Thread starter
- #61
Well I got the new engine mocked up in place, and started making new engine mounts when I found a bit of an issue... There is no space left for the fan.
Remember when I said that I was glad that I caught that I needed the longer input shaft with this bellhousing well it turns out what I really needed was a shorter bellhousing. The long input shaft is ~2 1/4" longer and the engine is currently ~2 1/4" too far forward.
So now as I see it I have 3 options.
1. Move the Transmission: would require a fair bit of fabrication (cross member, center tunnel, prop shafts, etc.), and then the carpet would no longer fit.
2. Use electric fans: Actually there would be barely enough space for this. (<1” between belts and the fans) Also all other items connecting to the engine are off so it would require some modifications of other parts.
3. Find/make a new bell housing: My initial search leads me to the conclusion that the correct bell housing doesn't exist, so make maybe my only option. This will also require tearing down the transmission to change the input shaft back. However it would be the cleanest option.
I am currently leaning towards option 3 (I would be getting some help with making the bellhousing). Any opinions?
