GX470 HID Projector Retrofit (2 Viewers)
Not in the short term...the cost involved vs return doesn't calculate... just opening the lights and removing bracket is 3-4 times harder then the LX. The OEM bracket would have to be cut and the new bracket attached to the remaining portion.. The GX has one large bracket housing both low and high beam so a new bracket would have to be attached to allow full adjustment. I'll continue working on this and might offer fully retrofitted lights in brand new OEM housing.
I've subscribed to this thread so hopefully if you follow through I would be interested in a custom projector bracket.
At this time I'm not going to finish this retrofit..... the cost vs return doesn't calculate. For those with the time this retrofit can be done and hopefully the limited information I post might motivate you to build a set but a finished plug and play set would run $1600 plus once I have a finished bracket. Sorry guys I was hoping to have an option to offer.
Darn! Thanks for trying though. Would you recommend to use your H1 bracket as a base to retrofit a Mini H1 7.0? Also, did you revise your Hi-Lens LED mount at all?
I did hack up one of my brackets to mount the Mini H1 and I haven’t touch the light since I posted the pictures.
The Hi-Lens would be very easy to figure out.
Opening the lights and removing the OEM bracket was a total PITA.
What a bummer. The LX retrofit has totally changed my driving habits and how comfortable I am driving at night.
So did you ever actually finish? I know you aren't pursuing them from a business standpoint, but just wondering if you ran into any hard stops. I've done a retrofit in my 99 Tacoma (easy) and 17 Tacoma (PITA to get apart, simple RX housing bolt in). I'm looking at possibly picking up a GX in the near future, and after a proper HID Bi xenon retrofit... it is at the top of my priorities with a new rig.
Bi-Xenon is a must if I'm going in there. but I'm really wondering how those LED's worked IRL
Never finished the GX retrofit but I'm running the LED High Lens as a DRL/High Beam in my LX and @jerryb came up a solution to run the Morimoto 2Stroke LED as a DRL/High Beam in 03-2007 LC and LX. Both are nice and give you a white DRL instead of the yellow color of the halogen and additional high beam for those running a Bi-Xenon in the Low beam location. There was a guy that posted pictures of nice bracket to run a quad setup in the GX and stated production was 3 weeks away.... that was in Jan. Never posted his finished lights, has 8 total post on Mud and went dark. My suggestion would be to buy a 100 or LX470 both are easy to retrofit.
The hard stops for me
1: Opening the lights (total frustration) I can open a LX Lens in less then 60 seconds once it's removed from the oven...More than 15 minutes to get into the GX..had to bake it twiice.
2: Removing the OEM bracket (total frustration)
3: The size of the light would make sealing them back up and a total PITA
4: Cost to make a bracket
5: Don't own a GX
6: Tossed the brand new GX Lens and hacked up housing in the trash
First picture is the 2 Stroke LED and other 3 are the LED HI-Lens
Thanks for the reply. have you ever done a 3rd gen Tacoma retrofit? just curious as to the difficulty comparison. I got my 99 lights apart in about 90 seconds, the 17 took me over an hour with 4 different re-bakes and even then I jacked up the housing trying to pry it apart. That damn adhesive is insane.
when you say size of the light in regards to sealing them back up, do you mean the projector, or the actual housing? I'm confused.
anyways, the LX looks great. off to read those threads. THANKS!:cheers:
Hi there I recently have dove into headlight retrofitting (i know im pretty late in the game)
I have 2003 Gx470 and bought these YUFANYA 2.5Inch Honeycomb Bixenon Projector Lens
Here is the problem, while you can only get two 2.5in honeycomb Projector lenses with a cool halo ring, they don’t fit what so ever.
I took them apart and roughly implanted the 2.5in honeycomb lens into the high beam lens. Now I am trying to find a 3.25in honeycomb projector lens for the partnering regular beam. Does anyone know where I could get one? I have searched a lot and have not even found a normal 3.25 in lens that replaces the one I took out.
Also, how do you take that grey housing that the projector lens sit in out of the whole headlamp? There is an inclosed, perfectly unreachable nut that holds everything in the middle and idk how to get in there.
Thank you!
Thank you!
I don't think there is a honeycomb projector for the low beam. The projector in the pictures above is simply for the high beam
My apologies, for the gx470, there are two projector lens’. On the gx470, the small lens belongs to the normal light that is on normally. The big lens, thats 3.25in. It belongs to the high beams. Is there a 3.25 in honeycomb lens?
I never knew those multi nipple lenses existed. I originally thought of these when you mentioned "honeycomb projector": Infiniti Q45 HID projectors on fleaBay
