I'm think'n it's more dependent upon mileage, so yeah the early models will be more prone to it.Isn't the valley plate leak more common in the MYs 10-13? or is it just an issue that arises after a certain amount of time, regardless of MY?
I think the reason you see that in the 10-13s is due to the mileage and age of the vehicle. Not the model year.Isn't the valley plate leak more common in the MYs 10-13? or is it just an issue that arises after a certain amount of time, regardless of MY?
I thought I read somewhere that it was due to the type of sealant used in those model years or how it was applied?I'm think'n it's more dependent upon mileage, so yeah the early models will be more prone to it.
But not having had it happen to me yet, i'm just spit-wadding here. Nothing has changed with the engine from 2010 - 2023 to cause one year to be worst than another.
Hummm. Never heard that, but perhaps Acrad can chime in. He's pretty on top of that kind of stuff.I thought I read somewhere that it was due to the type of sealant used in those model years or how it was applied?
I’m just hoping I dodge that bullet![]()
I thought it was mostly 2010-2014 before they changed the material used?Hummm. Never heard that, but perhaps Acrad can chime in. He's pretty on top of that kind of stuff.
I am somewhat convinced that if proper PM is taken, and the vehicle doesn't have fatal design flaws, (cam phasers in fords for instance) that any vehicle can be as reliable as a Toyota, and a Toyota on the same note can be a basket case full of issues if is not PM'd correctly.All I've done is the throttle body and think the dealership screwed it up cleaning it. The rest was all wear items like suspension and brakes. First owner replaced my radiator and one wheel bearing around 90k though.
Maintenance. Maintenance. Maintenance.
Radiators don't count since they are universally poor these days because of the plastic.I've had to replace the radiator once because of a plastic piece that broke. It was part of another repair I had done, but can't remember what that other repair was. So it must not have been very major.
With all due respect, I may have to challenge you about "...any vehicle can be as reliable as a Toyota..." if they follow at least these three considerations:I am somewhat convinced that if proper PM is taken, and the vehicle doesn't have fatal design flaws, (cam phasers in fords for instance) that any vehicle can be as reliable as a Toyota, and a Toyota on the same note can be a basket case full of issues if is not PM'd correctly.
Gonna have to disagree there. There are certain makes that no matter what you do they'll still be money pits. Plus the quality of manufacturing also comes in to play. There's a reason for example the GX is near or at the top for reliability. Made by one experienced crew in Japan.
Do I see another Lexus for your family in the near future????Haha. Yeah. My wife has a 2015 BMW X5 that we've had since 2016. It has 77k on it now. It was well maintained and low miles when we bought it. I've done all of the scheduled maintenance at BMW. Despite this, it has needed well over 10k worth of electronic problems and "wear and tear" repairs, including cpu upgrade, fuel pump, injectors, front control arms (all bushings were shot by 60k and the arm/bushing is one piece), and most recently (last week), it had to have the valve cover replaced due to a leaky valve cover gasket - also one piece thanks to the wonderful kraut engineers. I can already see the rear end sagging, so I'm sure control arms or struts/springs are next.
We had an C-Class MB before this and had it's own slew of electronic and mechanical problems around 50k (and ours was made in Stuttgart, before production moved to the US). No more German cars for us.
