@Nay , I don't understand this staitment... why use only 10" shocks if you can fit 12" shocks under your lift without restricting uptravel? As long as both are 12" stroke.
Front end can't use it, so you are further disconnecting the rear from the front. It's the same reason you want the front swaybar removed and rear attached - some resistance from the rear can help balance flex to the front.
It is also easier to keep the shock travel in the middle of the spring travel where the suspension is operating most effectively rather than essentially dropping out the bottom on one corner (there is no way to get equal action on the opposite corner without doing something like 3-linking). Think about what is happening with the sprung weight when one corner is still articulating but the other three are not. Where is that counter pressure being exerted and to what effect? Does this create an unweighting effect in some situations?
When thinking about "balance" as opposed to "travel" as a primary objective while maximizing tire size, I really like this video at about 1:10 when the rear suspension drops in.
An edit to my last post - you are right that my rear bumpstop drop is 2.5" and I had said 2" before.
Also, here's a current side view pic. That would be 24" hub to flare if I had flares.
