Genuine Toyota crystal clear corner lamp interest (1 Viewer)
Any OEM sets remaining in stock?
I am out of them at this time, will have more in about 2 months time. I do have a few DEPO clear corner lamp in stock a this time.
In stock =)
Still have oem clear corner lx470
Shipped 90018
Please let me know asap
THANK YOU RANMA21
HELLA FAST SHIPPING
Message sent. A deer took out a couple of lights and I figure I'm better off upgrading everything.
Would be very interested in clear OEM corner lights for my 2000 LX470. Awaiting contact! Thank you in advance.
Hi fellow mudder. Wonder if there is any interest for the crystal clear corner lamp for 100 series LC/ LX470. I am going to import some goodies for 80 series LC, I may get some crystal clear corner lamp for 100 series as well. It will be $179 plus $15 ride a set.
Note:
Landcruiser: Modification on existing socket required to fit.
LX470: Modification or socket with harness replacement is required to make it fit the corner lamp.
For direct fit and factory like installation, you will need 2 of each of the following items and swap the wire to the connector and install away.
Socket required for direct fit: 90075-60006 ( Required )
Amber Light Bulb for 90075-60006: 90981-15009/ 7507 Bulb ( Required )
Turn signal light harness/ connector for 90075-60006: 90980-11019 ( Required )
looking for a set for an 2003 lx470 please!
Looking for price shipped to 29526 for an LX on both OEM and Depo clears. Can you also supply the correct bits to change out for plug-and-play?
Thanks again to @ranma21! Had a cracked corner lens that was very dirty inside and I much prefer the look of the clear corners. These are the DEPO version with amber bulbs and swapped connectors.
