FSM vs. Owner's Manual - Spark Plug Gap
Discussion in '80-Series Tech' started by fuzzywuzzy, Jun 16, 2017.
  1. fuzzywuzzy
    fuzzywuzzy
    194
    59
    May 25, 2017
    San Diego, SoCal, USA
    Hi All - this weekend I'm going to be adjusting my valves in my continued attempt to pass smog and was checking the FSM I downloaded from online and there's a difference in gap recommendations between the FSM and the Owner's Manual that the truck came with.
    I downloaded the FSM from another forum, it has a blue/white cover and has, "TOYOTA 3F-E ENGINE REPAIR MANUAL SUPPLEMENT AUG. 1988" and then down at the bottom Pub. No. RM134E. On page EM-9 the states the gap should be 0.8 mm or 0.031 in.
    The owner's manual states 1.1 mm or 0.043 in.
    So my question is, is the FSM specific for each year? The sticker under my hood states I have a 3F-E CAL engine in my 91; is the 3F-E in a 88 different from the 3F-E in a 91 and would they have different gap requirements?
  2. Rifleman
    Rifleman
    1,030
    545
    Feb 4, 2015
    To answer your question, yes FSM can be specific to each year due to the fact that Toyota can, and will make changes from year to year. Next, since you don't have a FSM for your year truck, follow the spec's in your owners manual, as long as that owners manual is for the same model and year as your truck.
  3. baldilocks
    baldilocks GOLD Star
    3,429
    2,954
    Jan 29, 2014
    Northern California
    My 1994 FSM states .031.
  4. inkpot
    inkpot SILVER Star
    11,831
    1,730
    Jan 30, 2003
    Chandler, Az.
    Is yours a 3Fe also?
  5. fuzzywuzzy
    fuzzywuzzy
    194
    59
    May 25, 2017
    Yes- sticker in engine bay says 3F-E CAL
  6. fuzzywuzzy
    fuzzywuzzy
    194
    59
    May 25, 2017
    We're different engines available in 1991. Wondering if the owners manual is for a diff engine.
  7. Rifleman
    Rifleman
    1,030
    545
    Feb 4, 2015
    Your 94 has a 1FZFE motor in it, if I'm not mistaken he's running a 3F-E motor in his 91, that's a completely different animal then the 1FZFE is.
  8. baldilocks
    3,429
    2,954
    Jan 29, 2014
    Northern California
    My point in posting that info was that my fsm for a completely different engine concurred with his so .031 is probably correct. No telling what owners manual he has.
  9. Rifleman
    Rifleman
    1,030
    545
    Feb 4, 2015
    That's the reason i told him to use his owners manual in my first post, here's my quote, "follow the spec's in your owners manual, as long as that owners manual is for the same model and year as your truck" end quote.
  10. fuzzywuzzy
    fuzzywuzzy
    194
    59
    May 25, 2017
    The manual is for a 91 Land Cruiser and when discussing engine in the back it says 3F-E
  11. DirtScaresMe
    DirtScaresMe Trouble Maker SILVER Star
    522
    375
    Oct 8, 2015
    Mammoth Lakes, CA
    Same. Although I get shade from ih8mud for gapping the sparkplugs to that since they're pre-set with something better if you buy the toyota versions these days. I keep gapping them to the fsm; doesn't seem to have any issues.
  12. Dave 2000
    Dave 2000 Not all Land Rovers are useless! SILVER Star
    3,137
    676
    Jan 24, 2009
    Spain
    To the OP, spend a little time getting this right. Apart from the usual reasons to get the gaps right, the OE recommendations allow for gaps opening over time, if you start with too big a gap then initially no real problems, if the gap gets too big then this can cause issues such as lead failures and tracking around the cap/coil etc.
    Regards
    Dave
  13. fuzzywuzzy
    fuzzywuzzy
    194
    59
    May 25, 2017
    Doing the best I can, unfortunately when looking at the two options, I have to choose one and I went with the Owner's Manual for now. Yesterday I adjusted the valves, checked compression (new vehicle to me so wanted to see where I stood), and updated gap. Seems to be running smooth.
  14. Rivman1243
    Rivman1243 SILVER Star
    557
    Media:
    2
    Albums:
    1
    158
    Feb 27, 2016
    Helena Montana
    Isn't there a sticker in the engine compartment stating valve lash, timing, and plug gap
  15. baldilocks
    3,429
    2,954
    Jan 29, 2014
    Northern California
    @LS1FJ40 is a 3fe guy from way back. Maybe he can shed some light on your situation.
  16. fuzzywuzzy
    fuzzywuzzy
    194
    59
    May 25, 2017
    Lash and timing yes, gap no. I'll lol again tonight but didn't see it before.
  17. LS1FJ40
    LS1FJ40 SILVER Star
    7,976
    10,766
    Aug 9, 2005
    Cedar Rapids, IA
    I don't know what the gap is supposed to be. I always buy the plugs pregapped. @jonheld probably knows off the top of his head.
  18. BILT4ME
    BILT4ME
    3,910
    Media:
    3
    Albums:
    2
    3,293
    Nov 9, 2012
    Olathe, KS, USA
    Are you talking about SPARK PLUG GAP or VALVE LASH?
    The title says Spark Plug Gap, but the first sentence states "I'm going to be adjusting my valves". Typically , adjusting the valves is NOT addressed in the Owner's Manual, only in the FSM.
    Otherwise, follow what is stated in your year-appropriate manual, whether it is owner's or FSM.
  19. fuzzywuzzy
    fuzzywuzzy
    194
    59
    May 25, 2017
    Was going to be tearing into the engine anyway, needed to adjust valves and check compression and figured since I was going to elbow deep in things might as well update plugs if needed at the same time. Ended up gapping spark plugs based on owner's manual.
  20. jonheld
    jonheld
    6,838
    1,635
    Dec 8, 2006
    New Jersey
    There was a difference in spark plug gap between the FJ62 3FE and the FJ80 3FE. There is a different ECU and different coil/igniter. The smaller gap is from an FJ62. The correct gap for the FJ80 version (assuming you have the rest of the FJ80 components) is 1.1mm.
    Valve adjustment specs are printed on the sticker under the hood.
    Valve clearance (Hot):
    Intake 0.20 mm (0.008 in.)
    Exhaust 0.35 mm (0.014 in.)
    LS1FJ40 likes this.
