FSM for 200 series (7 Viewers)
Mine wound up estimating 19 days for a single seed to download, and seed dropped off 2 days in. Guess I'm sticking with the server based version, which is gonna be a pain without a laptop lol
Try it now, for the days I'm home it should seed at 1Gb/s (on my end anyway)
Roger that, fired up and oscillating between 8 and 800kb/s lol. Will leave it up and running for a while and see if it makes good headway. Appreciate the seed, thank you.
Are you on both trackers? I'm getting a failed connection to openbittorrent.com. Five peers on the other, but none are leeching.
I'm seeding as well.
Also, I followed the instructions to setup Abyss but I can't get the links to work. For instance, when I click the link for the 2016-2021 repair manual, I get the following that opens in a new tab:
And I did make sure to follow the jsp step:
Any ideas where I might have went wrong?
I thought I was, but looks like openbittorrent.com is throwing a Connection Failed.. not sure I really possess the tech know-how to troubleshoot that in an educated way. "Scrape Error trying to connect to tracker"
Edit: 90 minutes left, than kyou guys
If you (or anyone) isn't getting a download moving along after a few minutes, check your firewall rules. Often torrents get blocked by default. There are a few of us who are always seeding, so it should typically download in a few hours over most broadband connections.
Thanks for the FSM. Just got a 2013 LX 570. I saw just like myself, there were several people struggling to finally be able to view the FSM and it would just download a small file (44.2kb) simply named "Download" even though I followed the steps perfectly. I don't know why, but it only does this in chrome and if I navigate to 127.0.0.1 on Edge browser (Win10), it opens up fine.
Thanks for all the work putting this together. I am currently working on downloading one seed that is available. Any help is appreciated. Once I have it downloaded, DM me and I will help seed.
You probably downloaded from me. I'm always seeding
Thanks so much for your work @linuxgod !
I have benefited from your work and try to give back a little by at least part time "seeding". Looks like I've uploaded about 7Gb in the last 24 hours.
Cheers,
Jim
Seeding would be appreciated. I've been trying to download the last week or so.
I am showing that it's timing out trying to connect to the tracker right now. I've seen that occasionally happen and then come back... not entirely sure why TBH. Last time someone downloaded from me was 6 days ago.
I've updated the torrent with some other trackers, so try this link in your torrent client and see if it's more successful. It seems to be announcing to opentracker.io in the list now so maybe this will work better?
magnet:?xt=urn:btih:cf1ba674b5796aade66d13a51e7f4c56b8fb9195&dn=TheCompleteTLCFSM2021.iso&tr=udp%3a%2f%2ftrackr.opentrackr.org%3a1337%2fannounce&tr=udp%3a%2f%2fopentracker.io%3a6969%2fannounce&tr=udp%3a%2f%2ftracker.torrent.eu.org%3a451%2fannounce&tr=https%3a%2f%2ftracker.tamersunion.org%3a443%2fannounce
I've added this new magnet to my home torrent client. Its been about an hour and I'm still not downloading. Would the trackers listed have an issue with connections from another country? I'm using a VPN to tunnel torrent traffic out of the USA. I was able to download a different torrent about 2 months ago over the same VPN. Thanks for putting in the effort on the FSM! I've used it many, many times.
@linuxgod : Anything I can do to help out...preferably in a way that doesn't effect my bandwidth? lol
Worked for me a few weeks ago on my Mac. Note that after I downloaded the ISO file, I was able mount it as a virtual drive using the Disk Image Mounter utility. Therefore, I didn't have to go through the process on using a Web Server/Abyss.
Furthermore, I downloaded Abyss not knowing this and wasn't able to get it working that way anyways. Possibly since I'm not super tech savvy when it comes to Mac but either way....got it working.
You can seed but set the upload bandwidth really low. That at least ensures there's a torrent available and active for folks. Mine has a 10Mbps limit set since my upload is about 25Mbps, but you could set 1Kbps if you want.
Practically speaking I have NFC why it doesn't "just work" for everyone. I have 4 trackers set, and I have "announce_to_all_trackers" enabled, so any of these *should* work...
I downloaded from a day ago (with download speed 1.5 - 3 mb/sec) (using Qbittorrent) it's take a 3 days to finish all the file ( average 4 hours per day) and I do all the steps you explained in your instructions (post #45 and #46) and working perfect . thank you very much
mods, please delete this post. thx
