FSM for 200 series (1 Viewer)
Some firewall settings can get in the way of torrenting. I'd just start searching online for troubleshooting torrenting on your application and OS. It could be a ton of things, but they often have logical steps to go through to figure it out.
Mine is announcing to two trackers, and shows 4 peers online. So people do have the file available.
Sometmes you ISP can even be the culprit.
I had to select the option "pick a random port every time Transmission is started" and restart the download. That did the trick. I had also allowed Transmission as an exception in WIndows Defender but I don't know if that had any effect.
Yeah, when I initially downloaded the torrent, I also needed to select the "pick a random port every time" option as well.
The windows defender exception is probably what fixed it for you. The port shouldn’t matter
Anyone wanna seed a bit? I'll keep mine on for a while after.
I somehow nuked the magnet that was referencing my .iso. It's verifying again and should be online in 5 min or so.
Mine should be seeding, but I have yet to see anything connected to it...
I am always seeding. If it’s not working make sure your firewall isn’t blocking connections.
Thanks guys, i came home and it was complete.
It teetered between 2 and 3 when i started but at a slow crawl.
Must have picked up speed while i was doomsday shopping at costco.
If anyone needs seeding later feel free to ask.
One thing that noticed recently is that in the wiring diagrams the images of the pins and their part numbers are missing. I’m pretty sure I can go back and add them but at some point when I do I’m going to have to re-spin the ISO and post a new torrent. Most folks won’t need them but if you do (like I did) it’s annoying that they aren’t there
Whenever you do it let me know and I'll ditch the current file and seed the new one when possible.
Same (or at least I'll attempt to seed the new one...).
Thanks. I'll post the updated torrent here when I do. Quite a bit of change at work since the start of the year and I've taken on a bunch of additional teams, so I've not had time to spend on my hobbies as much as I'd normally like.
No pressure. As you said those sections aren’t critical for most people.
Thank you so much Geoff
Merry New Year! It's beef jerky time...
With some much appreciated financial contributions from @greynolds, @grinchy, @CharlieS, @bloc, @Dunbar, @i4c4lo, @bemerritt, @clearmysix, and especially @Leelanau, I've been able to get a new TIS subscription and do an FSM update this holiday season. The updated FSM includes all US docs through 2021, as well as non-US models through ~2015. Specifically:
  • 200-series LC/LX US models 2008 through 2021, and non-US (EMEA, GCC, AUS) from ~2007-2015
  • All 100-series LC models (US and non-US) and all US LX models 1998-2007
  • All 80-series USA LC/LX models 1991-1997
  • Official USA FJ62 1990 docs
  • All the unofficial and semi-official PDF docs for the 40-series and 60-series that I know of that are floating out there.
As with the old version that many of you have, the new one includes both the online web-browsable docs as well as some massive PDF files with the same data. And just like the last version, I generally recommend using the web-browsable version whenever possible - the PDF files are thousands of pages and not indexed, but I suggest saving a copy of the PDFs to your phone or tablet so that if you break down on a trail and don't have internet service you can still view them and do text searches.
To get the updated FSM, this time I'm going to ask everyone in the mud community to help provide it. I've made the FSM available as a .torrent file, which will allow people to download from the pool of available members, and will allow anyone who downloads to help the rest of the community by optionally being part of the pool of members providing copies to others.
To get started, just add the following link to any bittorrent client. If you don't have a bittorrent client, I recommend using Transmission as it's free, light weight, and doesn't include any spyware.
magnet:?xt=urn:btih:cf1ba674b5796aade66d13a51e7f4c56b8fb9195&dn=TheCompleteTLCFSM2021.iso&tr=udp%3A%2F%2Ftracker.openbittorrent.com%3A6969&tr=udp%3A%2F%2Ftracker.opentrackr.org%3A1337%2Fannounce
Once you've downloaded if you want to help "seed" the pool for other downloaders, just leave your client running in the background. Transmission has some nice features so you can limit the number of clients and the upload speed or available time windows (in case you want to minimize the impact during the day but let people download at full speed while you're asleep). Just remember to make sure you select "Seed Forever" in the settings, otherwise you'll stop helping the community once two people have downloaded it from you.
Once you have downloaded the FSM .ISO file, you will need to set up a local web server in order to make the docs viewable. (Don't bother trying to just browse the ISO file, the website using Javascript and won't work locally in most modern browsers due to their security features). For most people I recommend using the Abyss webserver to do this. You can follow the instructions posted here:
Finally, since the 200-series is complete, this will likely be the last FSM update that I do. If you want an FSM for your future LX 600, GX, 4Runner, Tacoma, Supra, etc what I've done is posted the source code used to download and create the FSM, along with some rough instructions on how to do so in the following link. Feel free to use this to build your own custom FSM with any Toyota/Lexus/Scion vehicle you'd like.
Fantastic work! i would appreciate it if people can share it so it won't take 3 weeks for me to have the full file! :P
Are you trying to get the original linked file or the updated one? I believe most of us have moved on to the new file.
Hello! The new one on page 6. I have got it, awsome!
However....
I have some trouble with abyss.
Done all that it says in the manual but the lc200, or any others, doesn't open with this abyss program.
If i open with chrome, it half works.
The Tis does nothing, the pdf works, but by the rebuild of the engine, it says INFO behind the steps to be done, and when i press it, its doesn't work.
And i can not find the 1vd engine, only 3UR.
Any help would be appreciated, I've got the engine out in the garage allready and want something to fall back to :)
The “abyss” program is a web server not a browser. You are setting up a website on your PC essentially when running abyss. You should be running abyss pointed at the downloaded and mounted iso file. Then you access the data by navigating to localhost (or your IP if you know it) with a browser. I dont believe every option in the main menu is available. I believe only the USA options were scraped from TIS, but I could be wrong on that.
