front tow hooks
The factory tow hook sure looks beefy.
I too went with the Tundra hooks. They cost a bit more than the ARB's but look the part, mine were powder coated two tone black with the tow loops in red. Factory hardware is a high strength Grade 11 [**edit** this would be a special case 11.9 strength, positioned between the typical 10.9 and 12.9 bolts] , I will substitute with even stronger 12.9 bolts when I remember to order them
Your $90 should be spent elsewhere. Maybe an extra strap to add length. Or another spare tire or gas can.
I too went with the Tundra hooks. They cost a bit more than the ARB's but look the part, mine were powder coated two tone black with the tow loops in red. Factory hardware is a high strength Grade 11 (10.9 on most scales on US), I will substitute with even stronger 12.9 bolts when I remember to order them
Source for info on toyota class 11t equaling grade 11?
This is not a Toyota specific thing. Look up metric bolt grading.
the Metric strength grades 5.8, 8.8, 9.8, 10.9, 12.9 are alternatively denoted without decimal and is commonly marked on JIS bolts with the first number as 5, 8, 9, 10, 12 ... 11 is a non standard strength. that would also be a 90% yield thus 11.9 is carrying the full designation.
The "||" on the tow point bold heads is a logo commonly use in Japan by the engineers and roughly translates into English, "don't worry about it".
:):beer:
I had a great day fishing yesterday and now I have to go back to work, so I hope I could get a smile out of at least one person reading this.
In a perfect world, the factory tow loop has an excellent life expectancy, and even in an imperfect world, it will last a long time. However, one of my concerns lies out in the future...with the nicks, scrapes, rust, and gouges that come from a Land Cruisers well lived life. The extra material gives me piece of mind.
Another benefit is the larger diameter of the Tundra bar stock, it gives a much nicer bend radius for wrapping a strap through. It places significantly less bending stress on the strap fibers.
Ground clearance is an issue, as mentioned above.
I'd like to dowel pin the bases and put the bolts in double shear with a bracket that runs back and bolt to the frame.
Well there is still discussion that the tundra hook is actually weaker in design. Personally, I agree with that sentiment. I don’t see what tundra hook is any better.
Yes, it is. Earlier in the thread I posted a document from toyota specifically about identifying bolt grades using their unique markings. Note: none of them use standard metric bolt grading.
I’d still like to see documentation showing what grade 11 is, or equating Toyota’s bolt classification (5t, 7t, 11t, etc) to something more widely used.
It is Not a Toyota bolt classification. It is a Japanese standard (JIS) used by many manufactures. Where as the x.y number is an international ISO Standard meaning x = ultimate tensile strength/100 in MPa and y = approximate reduction for yield strength 8 = 80% of tensile, 9 equals 90% of tensile, ISO also allows for the use of a single x digit thus 5.8, 8.8, 10.9, 12.9 would be represented by 6, 8, 10 and 12. JIS/JASO standards TS numbering but with grades in between such as 7, 9, 11 and even a super grade 15 to replace an older steel that was prone to delayed cracking used for 13. YS is not noted but follows same path of 60, 80 and 90% of yield.
Nice pic. Tundra hoops are giant, compared to oem 200, and feel much more substantial weight wise. [ they're quite heavy ] ground clearance is a negligible concern, imo. Hardly an issue, cept for a few that shouldn't even be using tundra cast offs, bc they need something even better.
++1
I like the Tundra hooks.
Here are the stock LC200 front tow hooks:
Here are the Tundra tow hooks powdercoated red, of course:
Guess which one is the stock part:
Understated elegance:
HTH
Picked up my @TRAIL TAILOR parts from the powder coater yesterday. I bought the shock guards that color from Jason. Now on to install...
My .02 on the recovery points, definitely a want vs. need just like the powder coating.
I know blue isn't everyone's color but I think it really brings out the color in my Maxtrax's eyes. Lol
