Mandrake
Supporting Vendor
Hey, sorry if this is in the wrong spot, but I can't find a better place for it.
I'm looking at doing a SAS on my '06 Sequoia and would really like to keep it as Toyota as possible. I'm considering going with an 80 front end to include the control arms, housing, panhard, springs and shocks. Yep, the big tree's got a drivers drop and I'm aware of and willing to take on the work needed to flip the axle. I know the current going price for a drivers drop D44 is about a case of beer, but again- I'd like to keep it as Toyota as possible. I used to have a few 80's and am very familiar with how the front end behaves and would like to replicate that with my Sequoia. I do hear a voice in the background telling me that it'd be a good time to do a three link, but that seems more complicated than welding in two control arm hangers, more math, and provides way more flex than I need; the flex of the OEM 80 front end is more than enough for me. Hell, the IFS flex is, eh... doable... but the extra travel from a SAS would reduce/eliminate head toss and most importantly- no more LBJ time bomb.
That all said, this is my first foray into a SAS. I'm not new to fabrication, but I want to make sure all the bases I'm not sure about are covered before I move forward with the project.
If I were to get the caster and pinion angles spot on and use the wheelbase measurement to determine where to add the control arm mounts, is it reasonable to expect the 80 front end to behave the same under my Sequoia as it did under my 80s? I'm currently at a 4" lift and don't want to go any higher and since I'd be stripping the axle bare, I can reweld the arm mounts and knuckle balls where they'd need to be to get the pinion and caster angles correct.
Other bridges I know I'll need to cross will be WMS measurements (I really do want it to match the IFS width to retain the tidy look of OEM wheels inside OEM fenders and it is vital to me to keep the scrub radius as close to factory spec as possible), and all the other small stuff like drive shaft, steering box, ect... I'll address those as the planning phase progresses and before I start buying parts.
Thanks for reading my book, and I'm looking forward to reading some to the point responses that either confirm my thoughts or steer me away from it.
