YesSo if I used a rear housing, what diff would I use? The rear diff?
So I'd be running it on the coast side of the teeth, and would have to figure out something for the tie rod, unless that rear diff is also going to run upside down?
The coast side of the teeth on a 9.5 is what is used on most every other Land Cruiser. They have been plenty reliable and strong until you're pushing bigger power/tires over 40. There's probably some here that would say even larger, but that's the extent of my experience. As for the steering, you do high steer up front. This goes back into just linking it while you're at itSo I'd be running it on the coast side of the teeth, and would have to figure out something for the tie rod, unless that rear diff is also going to run upside down?
My argument, for either one, tons or hybrid Toy axle is simple: you're already in this deep, no matter what you do, it's going to be cheaper and less work to do something right once than to half-ass it and THEN do it right. If there's ANY chance you'll want to do it in the future, now may as well be the time.Oh, I'm easy to convince when there's no question in my mind. For one, I'm dead set on doing a three link. So thank you for that.
I'm looking at some semi floaters on ebay and it's not looking like the diff isn't offset as much as the front axle appears to be. I'm guessing one side of the tube would be shortened and the other lengthened? I'll get to searching here to find what others have done.
80 series, front and rear diff have the same offset.I'm looking at some semi floaters on ebay and it's not looking like the diff isn't offset as much as the front axle appears to be. I'm guessing one side of the tube would be shortened and the other lengthened? I'll get to searching here to find what others have dodone.
This ^^^^ 100 percentIf you're happy with the vehicle's capability, you're talking about a huge amount of work to solve a single weakness.
In doing so, you'll compromise a lot of OEM goodness that you seem happy with. You're adamant you won't use it beyond your current use.
Sounds like a sledgehammer to squash a fly scenario.
I think in general, when it comes to modifying cars, it takes a certain arrogance or naivety to think you can do a one off major conversion without compromising something whether it be handling, looks, reliability etc etc
I learnt a a teenager, modifying cars, you're modifying stuff that has thousands of hours of design development and design integration.
Messing with it ALWAYS has unexpected consequences.
Not saying you can't do it, or shouldn't do it, just saying even for pros, this stuff is highly complex, and ALWAYS involves compromises in design and outcome etc
Seems to me, you could solve the ball joint issue with aftermarket bolt in upgrades for less than you'll spend to hack up a vehicle you're clearly happy with. Not to mention the time it will take.
3 minutes of Google-FU turns up this, and I'm guessing there's other options
3rd Gen Sequoia Suspension & Accessories | TOTAL CHAOS
2023+ Sequoia: Upgrading your suspension makes a real difference in comfort, control, and capability. TC suspension systems are built for travel and adventurewww.chaosfab.com
Post a build thread when you get started. Will be a unique beast when you get it done.
As you know the Sequoia/tundra play pen is super quiet
We can use some action over there!
Also beware that the 91- 92 80 front axle's have smaller front brakes then the 93-97s
Come on guys 2 1/2 tons front and rear steer with pinion brakes is where it's at.
