Agreed...and anything would be better than the factory bench seat and lap belts. That was standard in '71, the year of my pig.
Another point to ponder is that if you use a three point belt and attach the pivot to the thin metal above the rear door, the other two belt attachment points still rely on bolts through the floor. If any one of these three attachment points fail, the whole restraint system fails.
Reinforcing the steel above the rear doors is not possible without removing the headliner and doing some well engineered structural work. A dangling pivot point could obstruct ingress / egress for the rear seat passenger. In my opinion, reinforcing the floor for attachment points is much easier and less intrusive (it can all be done underneath). The containment system in the seats with integrated belts is tried and true. General Motors had to pass stringent crash tests with those seats. Honestly, if you look at the way the seats were attached to the floor of the Trailblazer, you'd question whether the floor was strong enough in that application as well...but apparently it was plenty strong.
I'm not saying that my way is the only way, but for me it was the best solution...and like I said, the seats are super comfortable.
