SOLVED - Front right vibration under load - Comment my thinking (2 Viewers)
Update:
While checking any parts for movement I found the lower passenger shock bolt wasn't 100% tight. It was tight before and must have loosened up, which would explain why my issues got worse the past 2 weeks.
Tightened it up from under the car and it immediately got better. Will have to remove the tire, remove the bolt, clean and Loctite it before installing it again.
Then test drive and see what happens.
Guys: it’s solved!!!
Just got the car back from the shop doing a full knuckle refresh incl wheel bearing, needle bearing, bushing. Swapped in DBA rotors and pad at the same time. A new seals and gasket.
And what should I say: NO clunk, rattle or whatever at high speeds and/ or u turn under heavy load!
Take away for me:
Lifting and already doing some stuff down there you should also refresh the knuckle!
Really happy now and I hope it’s still gone after our 10 day trip to Mojave and Joshua Tree next week!!
Thanks for your help and thoughts!
