So my buddy finished cleaning up and doing a whole bunch of maintenance in the engine bay ('97 LX450) including fixing an oil pump leak (with kit from Wits End), new pump, new thermostat, heater control valve, filters, replacing all the coolant hoses including bypassing the rear heater core, new plugs, new 150A Sequoia alternator, pulleys, belts, fixed a radiator leak, fresh fluids all around - collant, engine, tranny, diffs, tcase.
Turns the engine on and everything sounds good - except this loud noise of what sounds like fluid flowing/draining through a pipe. My friend's been wrenching since he was 14 and until recently worked on diesel busses for the city - so not a road side or weekend mechanic
But even he was somewhat stumped initially, as we lay under the engine and listened to noise. The noise is so loud that after the engine rpm drops at idle, we could hear it standing next to the driver side door. I asked him what's going through his mind and he says "rod knock" maybe
Then we both thought it sounded more like fluids flowing and then he wondered if it was some fluid overflowing. Anyways, without much adieu, I present to you an audio (video actually but ignore the visual) of the said noise and wonder if someone can provide some input
Thanks!
Thanks!
