on the welding subject... are you dragging the wire towards you or pushing away from you...
if you drag it towards you then you will get penetration..
if you push it away from you u will get less...
angle the head of the whip over to 30degrees and push it away from you on a practice peice.. and dont move the puddle side to side just in a straight line... and watch your travel speed if you go to slow then you will burn thru...
hope this helps...
cheers
hope this helps...
cheers
. Not to get off on the welding thing but - Coolerman (or anyone), do you have an opinion on a MIG/brand I can get at a reasonable cost that would be a bit better than the bottom end?
