That is awesome, great job. If you get some measurements, I wonder if a simple filter like this can drop in, lawnmower type.
Where did you get that rubbery foam for the hole you cut on the outside? I've been looking for that material.
sub'd, cool stuff. After looking at your above pics it seems like it would be easiest to seal up all the other holes that are air inlets along that area and then cut a specific hole like you did to fit an aftermarket or readily available cabin air filter from your local parts house? Would be fairly easy to make some block off plates for the other access holes with some thin sealing foam tape and self tapping screws, then cut a specific hole to fit the filter of your choice? that way all the intake air would be coming in from that one specific hole you cut? just a thought, not sure if that is the route you are going towards or not?
No. I've just decided to create a tray with a retaining edge that will fit onto the blower scoop probability permanently with silicone.
Then all Ill have to do is slide a small common filter into it and slide it out when I'm done.
Will leave all current vents as is. Want as much air going in as possible. That scoop needs help. Plus would want water to go through for drainage and keeping that area clean.
Will first source a filter that will fit then a sheet of tin to make the tray from one piece paint it and glue it in place.
Stay tuned.
ah, ok I get it, so that large hole you cut is more of an access hole? I did not even think about water being able to drain, that is a good point. Would love to see someone make something like you are doing that we can just plug into that blower scoop.
question, will you have to pull that whole top panel to change the air filter or are you going to make an access plate in that as well?
I would design the cabin air filter box around a commonly used cabin air filter such as one used on Chevrolet Tahoes since they are also very prevalent in both the US and abroad. K& N makes a version that is cleanable. Wix 24483 fits some Toyotas...... Just thinking of something that would be easily obtainable by all.
I fully agree with the cutout of the top plate for installation. However, for a service port, is it possible to create a service "slot" in the firewall area that we could unclip a couple clamps, drop a hinged cover, and slide out the element, then slide a new one in?
Just spitballin' here........
Thanks I'll look around those makers of filters.
If you refer to this picture of the firewall
Would be tricky to move the wiper motor. Not much room above or below. It's sitting smack in the sweet spot.
But I commend you for the best idea that can't be done : p
OK I was thinking that the intake was to the RIGHT of the wiper motor in that pic. I've been think of a decent way to do this as well without having to remove exterior body parts to change the filter. The other thing that would be nice to incorporate if the K&N Brand of reusable filter was used would be to install an air purge kit on it as well with a 12VDC solenoid and a couple fittings and copper tube. I work in the dust collection industry and deal with filtration and such like this all the time, I just haven't applied it to my own LC.....Yet.
Of course, that would mean that the owner would have to have on-board air for a pulse system.
Keep up the great work! I've been watching this regularly!
Stay tuned.
