I am just catching up on this, looks like some good conversation? Ha! Anyone know if there is a rebuilt kit for the starter? Or should I just buy a new one? I think that is my next move.
@NeverGiveUpYota @jonheld Who am I to believe? Ha!
See post #7
from the dizzy faq
Dizzy FAQ
"The 81-87 ignition is uber reliable because the electronics are not all packed into the hot, vibrating dizzy. The finned aluminum heat sink seems to be of benefit also. Toyota moved the Ignitor to the inner fender from the head to help keep heat and vibration down."
But they didn't ground to the block again until the 100 series added a wire to block and firewall.
Sorry if you don't believe, but cleaning the hold down cage and running the ground wire works fab, and is simple and easy to try.
Seems to be up there with EGR clogs, and charcoal cannister probs, that "just happen", without altering anything else in the engine bay.
There are simple starter contact kits, even from the "HELP" series will work, but contact pitting and failure will usually cause some chatter before failure.
Nothing he is saying will have any impact on the starter functioning.
I'm a little late to this party; but my '83 displayed the same symptoms as the OP. I struggled along with the "tap the solenoid with a hammer" solution to get it to start. What I discovered is that over time the start circuit from the ignition key doesn't deliver enough juice to pull in the solenoid. So what I did is installed a relay that delivers full battery voltage to the solenoid. Problem solved. Check out any "Bosch" 30 amp relay set up and you will be golden.
SimS
Why not just replace the starter switch behind the ignition key instead of reinventing the wheel and creating a possibly unsafe (un-fused) ignition circuit ?
Those switches are not expensive and available aftermarket and a lot more reliable than a $3 Chi-com relay.
Please don't take offense, but that kind of stuff is what makes new old-truck owners say WTF did this P.O. do?![]()
@sims has a workable solution. I've done it before and it works fine. Put a 15 amp fuse on pin 30 of the relay and you will be safe.
You do realize that you can take the coil and igniter out of the engine bay and put them in your refrigerator and the starter will still crank the engine, right?
