Nice 55! Is that a late 60’s model? Don’t think many of them came with that plate.
I ran an auxiliary battery for many years on a tray I built that bolted up to some of the factory bolt holes on the driver side. The biggest problem is that the inner fender doesn’t have quite the same shape on the driver side which causes the battery to sit up a little higher. Wasn’t able to run a factory size battery, and had to find a battery with smaller dimensions to fit.
Later on I was thinking about installing a factory battery tray in that area. Removed the horn mounting bracket, and was devising a lower mount to give support on the bottom side. You can see the front part of the tray where it would bolt to the inner fender stuck out above the flange where the upper fender bolts to the inner fender and where the hood rests. It was questionable whether there would be enough clearance for the battery.
