- Joined
- Nov 5, 2010
- Threads
- 33
- Messages
- 713
- Location
- Southern Iowa
- Website
- www.springtailsolutions.com
It looks awesome, is the installation hard to do?
Doc
Doc
I watched the film-great product looking forward when it will be available!
hindsight said:It looks awesome, is the installation hard to do?
Wow, impressive.
Cant wait to see the final product...
If she looks good, and under a $100 bucks, count me in!!
Quick question on finishing the bezels. I noticed in the video, some had rust pitting, and then when you applied the transfer I saw no pitting. Are the pits filled in with the primer being used? And if so, what specific primer do you recommend as a good filler. As I can imagine allot of guys that are going to be doing this will be doing it on rusted and pitted bezels. I would like to use the "tried and true" method to ensure quality.
Also, I noticed on the Trans Am .Camaro example they had alignment marks that helped in the application, do these have similar alignment points?
Thanks for your efforts.
Very cool Daniel!
I'm paying some good close attention. I'd like to second the suggestion to reface a volt meter instead of the original ammeter.
The original ammeters were for 30A, with the late models getting 50A options, but many modern conversions are a LOT more than that. So I'm guessing that there's quite a few of us who would like to put a voltmeter into the original cluster so that it matches the other gauges.
Shoot, I've considered going all aftermarket simply to avoid the mismatch, but otherwise love the original gauge cluster.
Keep us posted!
Dan
Not to rain on the parade, but really $100 for a vinyl decal of the gauge markings? The application process is the same as any decal that uses transfer tape.
I drew up the art and has the same exact decals cut and have a full set and speedo set only sitting on my desk right now. If I had a run done it sure would not cost $100, try $25 shipped max. I hadn't sorted out alignment yet, but the speedo is easy with the stamping on the face.
My version (minus transfer tape)
Nice job Daniel. Great looking gauges!
Looks like you even tested the speedo for a few tenths. I also noted that you ground the rivet off of the gauges to remove the faces, then screwed them back on. Or maybe you just drilled the screw holes in the rivets, and the faces just about fall off.
What size drill bit--what size screw. That will help the guys when they do their own.
As far as the price, well I spent $90 for a bill dory PS bracket that had $5 worth of steel in it. Could have made it myself, but I leave that to the experts. Then I know it is right
Where you at now Biscuit??????
Working on revising my artwork a bit. I have some new ideas in mind.
