FJ40/45 H.D. Skid Plates
Nice unit. All bent/stamped with only 2 welded seams. Well designed and made.
Donwey has these for $250. It's a 3" drop. My exhaust and cat run inside the frame, I like having the drop on the driver side so I can move the cat down to reduce some under floor heat. I think I maye add some holes for ventilation.
Had discontinued for years (lack of interest), then Mud showed interest, so I recently built a batch, just sold them all in one week. Now needing to know if I should build another batch, or did I fill the demand ?????
Frame rails get closer as they go forward, sooooo my skid plate also has matching side angles (sides slightly angled to match frame angles), so if you go too far forwardly skid plate would be too wide, or too far rearward my skid plate would be too narrow. I think you are ok going 3-4 inches in either direction though.
Would this bolt in on an HJ47 also (Troopy if that matters)?
Mopdog, I already have you on the list, and now also Lil Dog.
SugarBear, should fit your HJ47, you decide, it's 29.93" wide at the front edge, 32.98" wide at the rear edge, and it has zero bolt holes, you drill to fit your frame.
