rusty_tlc
Dain Bramaged Member
WTG big guy.
Keith you da Man! Now for a smurf blue 60 series run! I bet you are glad you did it now huh?
Dylan
Looks good! I can hear those tires howling already.
Keith:
You probably know this already but what the heck: When you start rolling your rig be sure to take it easy for the first 500 miles (stay on the easy roads...avoid high stress trails/obstacles) due to your new R&P's. Use dino oil in the diffs right now...for the first 100-ish miles keep the speed under 45-50mph to reduce the heat build up within the diffs due to the new R&P surfaces trying to "polish/mate". I would run the rig for a max of 1-hour then allow a good 2-3 hours for cool down...and repeat for at least the first 100 miles. Then at 500-miles drain both diffs and put fresh diff lube back in. Repeat again at maybe 2,500 miles. I was still getting metal dust on mine after 10K albeit alot less than I pulled at 500 miles and then again at 2K (be sure to use a diff drain plug with a magnet to catch all this metal dust).
Be patient...break it in right!
