@FJRyder Hi...2002 SC430 53K miles...I ordered the resonator and removed the old one, but accidentally trashed the pads and the 189 resistor next to it. My resonator did test 8.7k ohms on center to right pin, left pin to center was 1 as well as both outer pins. See pictures. I can't locate the resistor on Newark (its a 18G ohms I think). I am fairly sure its the same resistor on your board. I noticed in your repair picture your resistor was mounted upside down when you installed the larger resistor. The resistor's close proximity seems prone to needing resoldering. So what to do next. Any Ideas?Glad you got it figured out and thanks for adding the additional info to help others that might have the same situation.
