2001 LC. ABS, VSC TRAC, VSC OFF, BRAKE, ACTIVE TRAC Lights on!
Naples, Florida
I know this has been discussed many times but I still have no solution. Lights just came on. 2001 LC. New Master brake assembly 3 Years ago. No codes with OBD2. The only other light on dash is SRS. Right squib B0131 Open P/T squib (RH) Circuit. My Innova 5310 OBD2 scanner will not connect to ABS & TRC & VSC module just above the brake pedal. Part # 89540-60160. Discontinued part from Toyota. Order used one from UAE. Stated that it worked. Switched out. Still same dash lights on and no communication with my Innova 5310 scanner. All fuses under hood have been tested and good. Brakes operating as new. Brake pump cycles as it should. Brake fluid at proper height. 1 year old Odyssey AGM battery. Full and proper voltage.
Can a wheel speed sensor be bad but not shoot a code? And cause these lights?
Would the seatbelt squib being bad cause these lights to come on?
Would a bad ABS relay cause these lights to come on?
If I go to Toyota dealer would they be able to dive deeper into the cause with more advanced scanner/ Equiptment?
Any other suggestions would be much appreciated.
Dan
Family Expedition Overland
Somewhere, USA
Did you figure this out? I have similar issue can't solve.
