First car, lx450! (2 Viewers)
I am noticing a bunch of what seems to be oil all over the left side of the water pump/thermostat area. Does that mean another gasket probably needs changing, perhaps oil pump gasket/front crank seal?
Picture of the affected area?
I wiped a bunch of it off, but especially down below by the black bar (in between the two pulleys) there's a boatload, can't really get a picture that far down. On the other side of the engine (driver's side, this is passenger's side) there's some grime/oil but it's covered in dust so I don't think it's a crazy leak.
Could be silicate from the coolant, or maybe whatever lubricant is in the refrigerant is leaking close by. Not too much oil on that side unless it was from before the new valve cover gasket.
Clean it up and monitor is probably the most sound advice.
Yeah I think I'll avoid changing any more gaskets till I get it running and can monitor it. Noticed vast majority of oil leak from valve cover gasket was around the 6th cylinder, not much on this end near 1st. But yeah I'll do that otherwise this car will never run.
For front main don’t i need a 304lb torque wrench?
I used one of these digital torque readers
they’re about as accurate as a standard garage torque wrench, about ±10-15% I think.
I’m gonna hijack the thread while we’re touching on the topic :woot: I technically overtightened my crank bolt to around 350-360 if I’m remembering correctly. Do I need to go back and get a proper torque? Is that super duper bad
Tighten it down until you break it off, then back it off 1/2 turn.
On the transmission lines, that #12 unicoil is pretty annoying to find nowadays. Can't really find any good suggestions for what to do on that, anybody have a preferably cheap solution?
Edit: did see someone use Continental GY12UBP E-Z Coil meant for 1/2" lines, not very expensive maybe I'll do that.
I was hoping you had figured it out when you linked the thread earlier. It took me forever to find mine and I was lucky someone had a few on ebay when I checked. NAPA p/n 9986. Called my local NAPA to see if they had one in stock and that part number was fully dead
Oh ebay was a great idea, most seemed to be from Australia but I just ordered the last one of these. Looks like it's about 30 years old but for $16 might as well try, they have that same part number 9986 on the page. If it does work I'll have an extra for whenever I decided to irresponsibly buy another 80.
Ordered $150 worth of OEM clamps too, so tired of project being delayed because I don't have the right clamps. Maybe it's just me but I just can't stand the look of those behemoth breeze clamps.
I have a few worm screw clamps here and there…..staring at me, begging to be replaced.
Finally back to work. Many forgotten hoses and clamps later, all the heater hoses are on. Haven't clamped anything yet I think that U pipe probably needs to be pushed in a bit more on the bottom hose, but should be mostly good.
Radiator is replaced as well, just waiting on the nuts for the fan clutch to swap water pump and and fan clutch. Transmission cooler hoses next and then it's really just putting everything back together (and figuring out where these random bolts I have laying around go).
Thinking should be fully good to go by next week.
Before you clamp everything down turn on the key and make some adjustments to the temperature control slider. Watch and see if the cable moves the heater control valve open and closed freely.
Glad to see you are on the home stretch!
Ahhhhh that is really good advice. I planned on flushing it too to see if I have any leaks in my hoses since I've replaced so many, I won't clamp anything down till the end then.
When doing swapping the transmission hoses, should I drain all the fluid from the trans drain plug, do all the swaps, and refill?
Or should I wait till I can run the engine and do all of this then so I can do it while it's hot?
