Finally a workshop/storage/mancave (1 Viewer)
Aw Damn, that's great man. I've always wanted a English Wheel. I guess that's what its called.
Yes it's an English Wheel. Now I need to practice the different techniques and follow the YT courses.:popcorn:
Can't wait to see you shape some metal with it. You're getting together some cool toys man.
Don't tell my wife, the advantage of a shop away from home is that you can buy toys under the radar.;)
After fixing the window in the blast cabinet and sealing a leaking air valve, I turned my attention to my cheap bead roller.
Started with a frame to keep it from bending during use.
Then I figured a stand will be handy.
With some cheap wheels. I have an old drill hammer with a broken hammer mechanism, looking at the possibillity to use it to drive the bead roller.
Found this one, it tested good and has a nice big window. Very happy with it so far.
Screen is 10 * 6,7 cm
It is color 4 as base color, dark between 9 and 13 and with a setting for grinding
4 sensors to detect the arch and works with solar and batery power.
All adjustments are made on the outside.
MetalWorks PROTECT 670
