Featured 100 - spressomon
314mm x 32mm stock; 355mm x 32mm Stoptech.
These are sweet! How do I go about finding out how much? I tried to look around online a bit, but couldn't find anything...
I've always been a bit underwhelmed by the braking performance of 100 (my prior vehicle was a bit lighter/sportier, so perhaps my reference points are just not reasonable), and would love to make a material improvement. My upgrade to stainless steel lines was a bit underwhelming in terms of any noticeable difference
I am guessing you need to run 18" wheel in order for these brakes, eh?
Sonk,
Bought them from LPI Racing. Monty was super to deal with!
For whatever reason they list them under the LX470 category and not the Land Cruiser category but they're the same part # of course...
83.858.4700.51 - Lexus StopTech Big Brake Kit - Front
You WON"T be disappointed. After a day of driving it I'm blown away at the improvement. The pedal is so high and firm now I have to adjust the brake light sensor on the pedal so they come on when I tap the pedal!
With the ART and Porterfield carbon/kevlar pads I could get the peak power but at the expense of modulation. You get both here plus, per Stoptech, incredible rotor life. I really want to get them on-trail to see how they perform.
Thanks for the link. I guess I should have known that they aren't exactly giving these bad boys away for free...
I wonder if with such notable braking feel improvements this upgrade would also increase the effectiveness of the atrac system (e.g., better modulation, higher peak braking force applied, etc.)
Either way, I think this just made the short list...
No photos to post right now but I wanted those that are interested in all things front upper control arm related to know we designed and fabbed a custom pair of front upper control arms to test on the SpressoWagon. They were just installed this week after a lengthy prototyping/fabbing process over the past 6-weeks. Looking forward to thoroughly testing these new units.
They are built around super heavy duty race quality ball joints; grease-able and rebuildable. We departed from urethane or rubber inner bushings to eliminate the binding and wear associated with these components on lifted/raised rigs.
Additionally the arms are adjustable so better fine tuning/positioning can be realized with respect to camber and caster adjustments/settings.
Looks very promising...stay tuned.
And, although I'm a little burned-out with all the custom projects I've (with the help of Sam and his excellent crew of guys at SAMCO Fabrication here in the Reno/Sparks area) performed on the SpressoWagon this year, I am currently working on a new Sanden mount and OBA system design.
The camshaft mount has performed above expectation. Its just been great to have an unlimited high volume of clean air (9+CFM) for all types of trailside uses. Its been super handy for blowing the dust out/off the rig at the end of each trail day; quickly inflating my Exped DAM mattress and tires; powering my blender attachment for all kinds of iced drinks :D; and powering air tools. But it is somewhat complicated and expensive to replicate in kit form for the masses; hence the motivation to improve and hopefully simplify the system.
I hope to get some trail miles in testing the new front UCAs over the next 4-8 weeks and then hopefully re-juvenated to move forward with my spressoFAB Sanden OBAv2 project.
other than wear components..... any other improvements with these UCA's?
Yes...adjustable positioning: In/out (more than the OEM cam plates) and more caster potential.
Oh yeah...and about 4 degrees more travel.
The rig is at the alignment shop right now but just got a call from Mike my alignment guru and looks like I'm going to be able to pick up 1 degree more caster. We could get more but the sawzall would have to come out :D.
Stoked.
We built a jig so future units will be a little easier to build. There's always a few tweaks for subsequent production and I already have a couple in mind for these...but nothing major.
Over the next couple months I'll get to see if the project is viable or not from a performance perspective. But as you can imagine given their features, uber robust construction and hand-built build they're not cheap. But in the end, for those that rack on the off-road miles, they actually may be less expensive to own over the long term.
The Stoptech Big Brake Kit OTOH is just crazy big performance gains! I've thought about these for 2-years and my only regret in the limited amount of time I've gotten to drive it so far...is why did I wait?!
Diff breather
As some of you know I've had my fair share of rear axle seal issues over the past couple years. I've repeatedly checked the breather line to be sure it wasn't plugged. But after another round of oil vapor on the nose of the 3rd, passenger side axle housing/rotor shield and at the base of the diff breather nipple fitting I suspected a plugged differential breather issue.
After hearing Sam, SAMCO (local racer fab shop owner), talk about pushed out axle and pinion seals on the race trucks directly from plugged diff breathers I decided to spend a little more time investigating. The issues Sam (his own truck as well as Chad Hall's race H3 truck) experienced was caused by diff fluid (they use 250 weight!!!) getting sloshed up into the diff breather line.
Originally I took the advice found here on MUD to run the rear diff breather line all the way to the firewall where it tied into the t-case and front diff breather lines where they terminated at a small fuel filter.
But upon removal of the rear 1/4" fuel line serving as the diff breather line I discovered diff lube in the line that was interfering with good breathing of the rear diff system.
Per Sam's suggestion I tapped the diff breather fitting to 1/4"NPT and am now running 1/2" ID clear tubing. I ran the 1/2" tubing directly up/vertical to the DS rear hatch along with a clear inline fuel filter.
I also ran the rear e-locker vent the same way only terminating up the PS hatch side...
If you have a similar rear diff vent run I'd give serious consideration to changing it!
Hopefully this solves my problem!
I'm almost positive a helicopter would be best at this point Spress...
:D
Screw that, he needs one of these. Who needs a helicopter when you can do this....
