Hey All,
So my truck just failed a smog check miserably. My HC numbers are off the charts:
Idle: Max 250 - Measured 323
2500 RPM: Max 200 - Measured 1020
I added a gallon of denatured alcohol to the 1/8 full tank before heading over there. I figured that would help me pass with flying colors... obviously not.
My 60 passed no problem a year ago when I bought it. The only thing that has changed since then is that I can't fully tension the belt on the smog pump because the bolt is stripping out the threads in the pump. Because of that, when it revs above 2000 RPM, the belt loses tension, and squeals like crazy.
1. If the belt is losing tension like that, could the pump not be turning enough to do its job?
2. If the pump is not doing its job at 2500 RPM for the test, could that cause my HC numbers to be as high as they are?
3. If not, where would be the best place to start looking? I think I have the emissions manual around somewhere, but it would be nice to narrow this problem down further before I start tearing into everything...
4. Or is the whole denatured alcohol thing just a practical joke that screwed me over?
Thanks for your help guys!
Neil
Neil
