Factory Diff E-Locker ---> (LULO LJ-70) (1 Viewer)
El-NINO... Lulo LJ70,
Thanks for sharing.
Great handsON stuff.
regards,
HelimanBD.
Hi All:
Lulo, !Muy bien! :cheers:
!Salute! :D
Alan
This is really nice work there and nice pictures. Just have one question, what is a 90 series ???? Did you mean prado or something because my RJ70 has a 8" diff that only came on FJ, Hilux, Prado, front of 80 series and 70 series.
Yes mate,
90 series = Prado
:beer::cheers:
- :wrench: Fan-Clucth REBUILD :wrench:
After emptying the old oil from the three holes to pour the silicone oil filled...
Before joining the two sides have to put the board outside, is not difficult, but can give problems...
(Toyota Genuine Parts) - Oil Silicon, Ref. Nº 08816 - 03001 ,
I bought three cans, are filled with two, but some friends have used up 3 cans, better to have more than one missing...
clean the blade ... ... now look like new
Making this hard, cruel and dirty work should never miss ...
Assembling ...
After installing, I have to prove that this is the average temperature a little low, but the temperature does not increase much when climbing hills or inclines to be very long... :clap:
I think maybe I won a few more HP... :D :D :D
:beer: :cheers:
got a make and model number for the switch? i am in the process of installing this into the frotn of my 70...
Factory Diff E-Locker ---> (LULO LJ-70) Part 5
Locker - Switch: ON-OFF-ON
Locker-Switch with LED Light... (help me to know if the locker is LOCK) :hillbilly:
:beer: :cheers:
AIR COMPRESSOR - Part 1
Remove the alternator mounting...
Strengthening the base of the alternator, which hosted the alternator and air compressor...
The air conditioning compressor, which is now air-filled wheels ... (AIR- COMPRESSOR) :hillbilly:
Install new base with the air compressor to check the correct position and then put the new belt...
The new base of alternator and air compressor is ready ... :bounce:
continue soon... :popcorn:
:beer: :cheers:
"El Niño" ----> Front Bumper *KB* Part-2
Looks nice :hillbilly: :hillbilly: :hillbilly: (only need the winch) WARN 8274 in progress :flipoff2:
Ready to apply background paint... :wrench:
Everything is ready for painting... (Part 3 :rolleyes:)
:beer: :cheers:
Very nice work you done for the Lj LULU. I have 1988 RJ70 and I just happen to find a rear axle with E-lockers on it from a Japanese model LJ78 long wheel base one. All the mounts on the axle where different even the axles where different ass it’s a rear disk breaks while mine are drum brakes. So I think I am just going to retrofit the new e-locker differential just like you did into the old housing. But I have one question. Did you use your original LJ70 axles and did you have to do any modes to them to get them to adapt to the new E-locker diff?? I heard that the tooth on the short axle is longer is it in your case??
Nice LJ you got there
Exellent work LULO!
I replace the old winch of my Warn 8274 for a more powerful motor (Bowmotor 5.6hp), also to check inside the winch, i found a very old-oil! :hillbilly:
My old winch motor is in very good condition...
A new 8274 motor... :flipoff2:
Revised and replaced the bearinghousing the new engine... :wrench:
:eek: NEW Warn 8274 "LULO Edition" :hillbilly: :flipoff2:
Change location plug the winch control...
...the rear bumper coming soon! :popcorn:
Great job on the E locker
Have 2 on there way from japan ATM , They may be slow to engage but at least they wont shop your axels to bits like a certain 3 letter one does from too short axel spline engagement.
Dave
