You check the EGR by pulling a vacuum on the blue line, with a hand vacuum pump or use your lips if necessary. If it opens, it will idle rougn and probably die. When you release the vacuum it should go back to idling smoothly.
What to do next? .
same thing happened to me. I dont know about Tenn. but NJ's inspectors HATE to even see older trucks. Its a given that you fail if your driving an old vehicle.
Mine had the same problem, and my exhaust was also bad, including a cat with holes.
replaced the cat with an aftermarket, and OEM cat-back, and passed right away.
If you are having trouble passing your local smog test and its a "closed hood test" like here in Wa. state and you dont mind cheating the system.
#1) remove the end of the hose that presently goes into your air rail. Put it aside (protect it fron the manifold).
#2) remove the exhaust (blowing) hose leaving the smog/air pump at the air/filter box end.
#3) put #2 where you disconnected #1.....you are now blowing air down your tail pipe severly deluting your exhaust emmissions
I went from "fail" to almost blowing 0s across the board. ///// I did get a raised eyebrow from the tester......same guy as the first test
Good luck
Can you tell us what the current tailpipe numbers are, and what the limits are?
Whistling is usually a manifold gasket leak, IME.
