electrical woes (lights) (1 Viewer)
LCL
Orinda, NorCal
My headlights do not function.
All but the two front driver side running lights work.
None of my flashers work.
I have checked all fuses, connections, and grounds. It looks as if a relay (is it?)
near the battery on the passenger side inner fenderwall is failing. Could that be the
source of my problems?
I could get a picture if that would help greatly. Thanks for any thoughts or
direction, this is my DD.
LCL
Orinda, NorCal
If the dimmer switch is in the cabin like I assume, I'm not sure I have one. Though I according to my
year, '70, it looks like I should. Do you have a picture or diagram of its location? Is it possible that my
newer alternator that bipasses my regulator is now a problem all of a sudden?
Prescott Valley, AZ
LCL said:
If the dimmer switch is in the cabin like I assume, I'm not sure I have one. Though I according to my year, '70, it looks like I should.
I'm not sure what year the dimmer switch was moved from the floor to the turn signal, but you've got one in there somewhere.
Someone should pop up here pretty soon with the wiring diagram for a '70. Otherwise, run a search on dimmer switches and/or headlight electrical.
Willamette Valley-Oregon
Try out this site, it is very informative and may help you figure out your elect. problems.
www,madelectrical.com
click on electrical tech and start reading about relay switches and alternators.
Users Who Are Viewing This Thread (Users: 0, Guests: 1)
