The whole brake system was flushed when I installed new calipers on the rear and EBC's at all four corners. It's wasn't the performance but the fade after driving through winding mountain roads downhill.
After I realized how hot and slippery the brakes were getting, I then started downshifting. That alone made a huge difference. I didn't think the driving we were doing would have overwhelmed the pads so quickly.Do you downshift for the downhill sections? Lots of folks don't realize it should be done the same way you would in a manual transmission rig.
Last month I did 2500 miles in my rig from Phoenix up thru Colorado and Wyoming. I did not have any brake problems on any of the mountain passes, and I do drive a bit aggressively. I have been accused of driving my 80 like a rally car. I ran all of Pikes Peak in low range. Lots of power for going up in 3rd and 4th gear, and lots of compression braking going down. The Park Rangers check your brake temperatures at mid point on the way down, and my front rotors were at 85 F degrees. By using compression braking I save my brakes for when I really need them.
There are no blues for the 80 series unless you go to a 100 series pad.
These are the most aggressive EBC pads you can fit to the 80 after removing the antisqeal backing.
Fronts
https://www.summitracing.com/parts/ebc-dp51319ndx
Rears
https://www.summitracing.com/parts/ebc-dp4993r
Do you run this combo, and if so, are there any noise issues?
