Early 40 glass horn relay?
Buffalo, NY
Found this in a parts pile. Early horn relay? All the pics I’ve seen of these are metal casing.
FYI, here’s the one on my ‘63 45. If yours has a “K” in a circle on the cover after you’ve cleaned it up it’s a Maruko.
There were two early horn relays, a Maruko and a Denso. There is also a metal covered one and a plastic covered one. I’ve seen a metal covered Denso (so labeled). This one is a Maruko.
The symbol K is for Keihoki, look at top of webpage banner (there’s English translation available):
I looked closely at your photo (background) to see if those were TNK wiper arms (they aren’t) which would be the same vintage as the horn relay, just in case you were selling stuff from your “parts pile” 😉.
Haha good eye. I think those are TNK middle to late 70s oem arms.
Not 60s era
I also have a bunch of hinges and rando bits. What are you looking for?
Early TNK wiper arms 😂! (the ones with the bolts on the side)
Early 3-bolt interior mirror (triangle bolt pattern, 64-65ish vintage)
