Updates! I've been doing all of this maintenence in preparation for a wheeling trip which I just finished up this weekend.
The day before I was slated to meet up with the group to roll-out, my truck would not start. It would crank and crank and crank but no turnover. I was pretty bummed and started doing some searching along with starting a thread. It turned out to to be the crank position sensor that was chafed due to the 90k service.
I welded together a simple tab setup for my CB antenna and also welded on a light tab from Gamiviti for a camping light which works awesome for night cooking!
I picked up a 32" lightbar locally which fits perfectly in between the ARB bars. I may re-do the mount with some security bolts to make sure some sticky fingers don't get a hold of it.
I installed my tank for my OBA setup under the truck. The cheapo PVC line I used will not hold up to the heat in the engine bay and along the frame so I'll have to look for another![]()
I disliked the orange in the tail lights so I opted to paint the tails before dropping $200 for a new set. I'll stick with this for a while.
Pics make it look frosted, but it actually looks really good.
Updated pics of the truck from the trip! The workaround I did for the CPS worked well and I had no issues all weekend.
Not much more planned on the plate until my BIOR rear bumper comes in. I'm having Mike create a few changes. I may have to level out the stance of the truck after it's installed.
I started to drill the frame and scab plate for the steering box. Since the frame is hollow inside, I drilled a piece of square tubing to keep my drill bit straight
3 hours later and many dull drill bits, the steering box is mounted up.
