Driveshaft Builder Recommendations?
SE is going to have a lot of local places.
I've used a place in harrisburg to lengthen prop shafts on my 75 and a 74.
Had a local shop build me one - terrible vibrations. I got those Tutton (?) eBay special builds on my 1970 CJ5 and aint had a problem but from what Ive read he's not the guy for the FJ40 builds.
It's not rocket science.
So take it back. Say "I got terrible vibrations". Any decent shop can fix it, it's not rocket science. That's why I go to my local shop. Every decent-sized town has a decent driveline shop, usually on the outskirts of town. I've been through a few driveshafts in my time, I've never had to send away for one.
The only reason I used Adam’s was to shorten and lengthen the shaft’s after the 4 speed install. And I was living 15 miles from there shop. They also put a universal flange on for the different size of the 4 speed from a 3 speed
If you like to keep toyota u-joint, you can have your old one modify to fit your need
Most new shaft use 1310 spicer u-joint
/this\
I had Tom Woods build the rear shaft for my 45. They told me up front that they would use the Spicer. I happen to like the additional stand off from the flange that the Spicer has, so I went for it.
That was 15 years and a lot of miles ago.
