- Thread starter
- #101
My local wrecker has a 4 runner shaft for $100 will it work ?
It will on the REAR of the cruiser.
The Tacoma shaft needs to be from a 4x4 or prerunner without a doubt.
Well, a little further along now. The non-cv end of the earlier cv front shaft bolts up to the FJ80 diff with no problem. I called Inchworm today to confirm that one of the three flanges offered would fit the front output of the FJ80 t-case - no help there. Apparently, they have no cross reference data on the FJ80??? Guy told me to pull my shaft and measure it.....thanks. I'll try to get that done tonight unless someone has the bolt patern information on the 80's t-case handy.
Just so you know, the "flange" on both the front and rear outputs on the 80 t-case isn't replaceable like mini t-cases are. The flange and shaft are all one piece on 80's.
Jack
ONLY ONLY a Tacoma REAR shaft can be used for the FRONT of the Land Cruiser. I've cut open another Tundra shaft and seen first hand why most drive line shops cannot or are not will to do so. The rear shaft off an Xtra or Crew Cab Prerunner/4x4 Tacoma will work.
The Tundra shaft is "fused" at each end where as most other Toyota shafts are sleved over welded. The Tundra shaft can be re-worked by the few shops that have the ability but the shaft will not be very robust. I dumped the Tundra shaft I had and went with a Tacoma. You should do the same.
BTW, sorry my whole write up is a cluster f* to understand. Once the shafts are viewed in person it will all make sense.
it should
From what I read it looks like 32" is the magic number for the shaft length for the front.
